586,075 active members*
4,183 visitors online*
Results 1 to 6 of 6
    Aug 2011
    61
    Diamond drag engraving
    How deep do the diamond drag engraving tools engrave to?
    Jan 2007
    869
    Re: Diamond drag engraving
    Not very deep, it is a scratch line. Probably a few thou deep.
    Wade
    Aug 2011
    61
    Quote Originally Posted by wwendorf View Post
    Wade
    Is it more than .003?
    Aug 2009
    610
    It depends on the material. I typically multi-pass drag engrave while changing the Z-depth level to get more spring pressure. I have a hard time getting deeper than 2-3 thou in stainless steel even with multiple passes. Typically the more acute angles of the diamond point will allow for more depth, but the lines generated are VERY fine. I posted a video on youtube some time ago that shows diamond drag in 304 stainless. If you haven't seen it you can check it out.
    https://youtu.be/XdswlEzv5Og?list=PL...0yH600MA6CYHk5
    Jan 2007
    869
    Kind of hard to measure how deep it engraves as the point is so fine, but it does do a very nice job. I would probably guess .001-.002 with multiple passes.
    May 2015
    111
    When I engrave NFA items to meet the ATF requirements I use the carbide engraver because I can not get a deep enough cut with the drag engraver. I have tried multi pass on stainless and the best I can get is ~.002 . Even engraving aluminum I am not sure I could get deeper that .003 consistently.
    Chris
  1. A Little 4th Axis Diamond Drag Engraving
    By pickled in forum Tormach Personal CNC Mill
    Last Post: 06-29-2015, 02:01 AM
  2. Marking/Engraving Chrome/Finished items. Laser or Diamond drag?
    By Zeppelin1007 in forum Engraving Machines
    Last Post: 02-02-2015, 07:20 AM
  3. Widget works diamond drag ??
    By poorfarmer25 in forum WoodWorking Topics
    Last Post: 07-23-2012, 08:20 PM
  4. Diamond Drag info needed. Looking to buy.
    By ibuildstuff4u in forum Benchtop Machines
    Last Post: 11-02-2009, 06:45 AM
