In the process of the machine use,Fiber Laser Cutting Machine is to ensure the quality of the incision-cutting tip and keep the workpiece surface height basically the same.
As the speed of laser cutting machine,which is extremly fast, the operator is not able to hand-tune the cutting-head to maintain a good quality. The speed of response is certainly unattainable. Especially, when cutting sheet metal, or the surface with texture and flatness, or cutting in case of limited processing environment, it is important to keep cutting with a high degree of stability. When metal laser cutting machine is used,the cutting head will walk according to the cutting path setting. However, in the case of different materials, different thicknesses, different cutting methods, laser cutting head height needs to be adjusted by the control, and the distance between the tip and cutting workpiece surface determines the incision quality. Also, the cutting speed of one of the main factors in terms of controlling.
In addition, metal laser cutting machine need to select the appropriate cutting nozzle type and pressure parameters. According to the cutting situation- the material thickness on the cutting head and steel plate thickness, it has to use different parameters. Cutting nozzle should be adjusted to the appropriate height.
At VICCAM, in order to make manual adjustment of the cutting height and compromise the control instability,metal laser cutting machine is equipped with imported servo to make the capacitance increase. Thus, Whether thickness it is cutting, it would able to increase the capacitance for the cutting head, a high cutting quality can be consistent.
The principle of the capacitance increasing is: capacitive sensing ring to form the capacitance between two plates,and it is automatically connected with capacitor size and the distance between the two.
