Hi everybody,
I know many users have a chinese laser, maybe it's a problem for you when you see chinese on software or panel.
Today I will teach you how to change the language on panel.
http://www.thunderlaser.com/troubles...chinese-2.html
Hi everybody,
Hi,everyone.This is Amy from Thunderlaser.
Some customers asked me how can I know how long will it cost it cost to make a working piece.(before I start the laser)
Now I will show you how to calculate working time.
Pass- Through Door Design
Just imagine someday when you need to cut a super long material and the table of your laser cutter is not long enough, what can you do? Using a saw to cut the material into small pieces first? That would be a waste of time and might damage the material a lot.
Don’t tell me that your laser cutter does not have a pass through door design! All Thunder laser cutters has a pass through door design to deal with such case, you can learn how to use this function easily from this video.
https://youtu.be/tv4wjChAHAA
Hi,all
I will teach you how to Draw Simple Graphics on laser cutter software rdworks v8 tutorial 01
Hi
If your laser cutter's LCD panel is in Chinese,it might cost you lots of time to set to English.Now Thunder laser will show you how to change Chinese to English just in a few seconds.
Step 1. click "Z/U" button
Step 2. select"语言设置" and then press "Enter" to confirm
Step 3. select "英文" and press "Enter" to confirm
Now it's in English
You can learn more details from this link:It is not find the information you need.-
Hi everyone, this is ken from Thunderlaser. In this lesson, we are going to learn how to engrave a photo. Let’s load a photo first. Click import button and select a photo. Then click open. Now we can set the size of the photo and then click “BMP” button.
Then tick “set output resolution” and input the resolution as 1000.it is suggested to set the resolution between 1000 and 1500. Then click “Dither” and choose “Net graphic” and set the Frequency as 30. Then click “Apply to view” and enlarge the photo to check the detail. We can see the dot size is too big. Now we can change the frequency to 50. The quality is much better now. Usually, it’s suggested to set the frequency between 50 and 70. If we need to engrave transparent materials like acrylic, we should tick the “invert color”.
And that’s all for today. See you.
https://youtu.be/3NdtQh0HPi4
Hi,everyone..Some customers asked me how can I know how long will it cost cost it cost to to make a working piece.(before I start the laser)
https://youtu.be/fcdJZTHsQl0
today i show the video how to Change the Layer !
https://youtu.be/fgxGz01xUIg
Thunder laser will keep providing you the most professional and easily understanding guiding videos on how to use a laser cutter
Hi everybody, this video will teaching everyone how to Flip an Object
https://youtu.be/wQHlUSvOOGc
Hi everybody,
this video will show to how to Select Objects of Same Color
Hello, everyone, this is ken from Thunderlaser. Now we will learn how to change the criterion of coordinate.
laser cutter software rdworks v8 tutorial 09 How to Copy Objects Quickly
laser cutter software rdworks v8 tutorial 10 How to Engrave a Photo
We learned how to deal with a photo from last lesson, now let's see how to set the parameters for engraving before sending the file to your laser cutter.
https://youtu.be/qUK8eiPXY58
Hi guys, now let's see how to set the parameters for engraving before sending the file to your laser cutter.
the video will teach you learn how to set the cut parameters.
Laser cutter software RDworks v8 tutorial 13 Combine Engraving and Cutting
Laser cutter software RDworks v8 tutorial 14 Difference Between BMP and Vector
https://youtu.be/G6WH8diX4_I
