how ?
hypothetical ?
Let's move 1" away from a part using M203, and index from #1 rougher to #2 finisher using M66. If approach move is small, you will be cutting before the turret is clamped.
program duration varies ... somewhere arround 0.1..0.5 seconds @ each 60 seconds; same part comes with different machining duration, and this deviations, for a 3 minutes program ( ~ simple part) are at a larger scale than 0.1 ; maybe 0.3 .. 0.5, if not 1 second at least, so targeting time economy under 0.5 .. 1 is not so relevant
i am not saying that someone @ cnc zone actually does that, but i meet people that were taking such economies very serious, but generally they don't see the big picture, as that the impact on program duration is small / however, this does not mean that they are wrong
is messed up, but is real as you and me, and is happening a lot of times: this is the explanation : people without technical experience often require controversial tasks ... some just to prove "who is the boss", while others (a few others) have knowledge and see things from a perspective that is not staggered if productivity is at 50% for a few days ... this is elite
from this perspective, CTR is useless, because overall, is not so important
I've worked with customers where 1 second translates into $50000/yr, so if I can save 1.5 seconds per index and index 10 times during a program, I've just saved 15 seconds. That's worth $750,000 to them annually. Now if you are a job shop that runs 5 parts, you will spend more time "optimizing" that you will save so it may not be as important.
Now if you have a Cad/Cam system, just put it in your post and all indexing optimization is automatic from now forward.
