586,106 active members*
3,206 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > G76 Threading plunges straight to full depth???
    Dec 2013
    7
    I have a Sieg IKC4 CNC slant bed lathe, Fanuc Type B I believe. Got an issue where the G76 threading command runs, but for some reason takes the first pass at full depth, and then pulls out and continues with the rest of the passes just cutting air. Does anyone know what could be causing this?
    Here's what I'm running, I'm told that the 2-line format is correct for this machine.
    G76 P050060 Q0.1 R0.02
    G76 X23 Z-20 P1 Q0.2 F2
    In this example I'm trying to cut an M25*2 thread, but the first pass is at X23.00 which is full depth. The next pass will then be at something like X23.42, the next at X23.36 and so on until the final pass is back at X23.00.
    Can't figure it out, any help would be appreciated.
    Cheers
    Feb 2011
    353
    Re: G76 Threading plunges straight to full depth???
    you are using dec. points in the first g76 line but the p in the 2nd line has no dec. point
    some fanucs 31i's from citizens machinery do not allow dec. points in the P,Q,OR R
    as these ae sub micron machines they are 5 place figures 00300=.003 and if not programed this way it does what you are talking about full depth on the first pass and .00001 on the subsequent passes
    M3S1=1200
    T200(9/16-18 THREAD)
    (LAY DOWN 18 TPI INSERT)
    G0X.662Z.775T2
    G4U.5
    G76P010015Q00300R00100
    G76X.4938Z2.360P03410Q00900F.05556
    G0X.662
    G0X.662T0
    you will have to change some as you are using metric instead of English
    practical machinist does have a good g76 description in there blog
    Dec 2008
    3109
    Ps & Qs cannot have decimal point
    so
    Pxxyyzz xx= # of finish passes,..... yy # of revs before Z depth for pullout,........ zz=plunge-in angle
    ..........Q is depth of cut in microns,.... R is depth of finishing pass
    so try G76 P010029 Q100 R0.02
    P is radial thread depth in microns,...... Q is depth of 1st cut in microns
    so try G76 X23. Z-20. P1000 Q200 F2.
    LINK
    Feb 2006
    1792
    P----60 would also work (one-side cutting)
  1. Thread milling single lip vs full depth cutter
    By DLawrence in forum Tormach Personal CNC Mill
    Last Post: 02-22-2016, 02:28 PM
  2. Full Depth of Tool
    By Darth Yoda in forum Mastercam
    Last Post: 06-05-2015, 07:48 PM
  3. finish cut on profiles at full depth
    By brian257 in forum Rhinocam
    Last Post: 04-13-2015, 10:55 AM
  4. help with precision depth threading
    By mwelch in forum Solidworks
    Last Post: 12-26-2014, 04:43 AM
  5. Eliminating tool markings on profile operations - full depth finish pass?
    By FoxCNC1 in forum Material Machining Solutions
    Last Post: 09-29-2014, 03:05 AM
