586,209 active members*
4,072 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > ultimax 3 problem with tool change in gcode editor
    Jul 2014
    19
    Hello all, i have a hurco bmc4020 with ultimax 3 control. i download a bnc g code program from cam system with tool change
    and spindle commands. then when i run the program it seems to skip spindle speed changes.
    is this conflicting with the tool library settings?
    thanks!
    Jun 2010
    104
    Re: ultimax 3 problem with tool change in gcode editor
    Which CAM system are you using to generate the g code? Post your g code here and I can take a look.
    Jul 2014
    19
    Quote Originally Posted by hkenuam View Post
    Using surfcam 2014
    Z0.847
    Z0.712
    G01 X-3.318
    Y1.15
    G40
    G00 Z2.3
    /(T2 .375 EM)
    M25
    G90 X-6. Y-6. M05
    T02 M06
    M03
    S1000
    G00 G54 X-5.595 Y-0.2657 A270.
    G00 G43 Z2.3 H02 M08
    G00 Z1.387
    Z1.187
    G41 Y-0.2845 F5. D2
    G01 X-3.0005
    Y1.15
    G40 X-3.0193
    G00 Z1.8
    X-5.595 Y-0.2657
    Jun 2010
    104
    I'm not at the shop to verify but I use Bobcad and I have a BMC4020. Looking at your g code, if you remove the 0's and do T2 M6 M3 see if that does a tool change and turn the spindle on to 1000 RPM.
    Jul 2014
    19
    Thanks for the help. I found that I have to have the spindle speed
    Before m03. Or it throws it off.
  1. Gcode then tool change?.
    By CosmicGlenn in forum USA Club House
    Last Post: 03-20-2016, 01:33 PM
  2. Gcode Editor Suggestions
    By vmax549 in forum UCCNC Control Software
    Last Post: 08-07-2015, 12:36 PM
  3. Use of M6 with the Gcode Interpreter: and Tool Change via M6...
    By jeffserv in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-11-2015, 06:47 PM
  4. Gcode tool change recommendations
    By emery in forum OpenSource Software
    Last Post: 10-05-2013, 09:42 PM
  5. Missing tool change in Gcode (SprutCAM)
    By bevinp in forum Tormach Personal CNC Mill
    Last Post: 07-09-2009, 02:26 AM
