I have drawn up and imported the solid in the attached to use as a Final project for my advanced Mastercam class. I WANT it to cut the inclined plane of the pyramid face using the hole as the boundary. I will follow the roughing with a minimal step over ball nose to get the surface quality I want. It does it BUT cuts down to the origin plane on the sides of the pyramid. How do I make it understand I want the side of the pyramid to be the cutting plane
All I have to pick is surface because that's all that came from the .igs file out of Catia.
I'm sure I left some info out, Ill try to explain it best I can
