586,115 active members*
3,304 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Am I Wiring this right? i have pictures.
    Jan 2016
    33
    I'm Excited to use my new VFD. although I'm stuck at something that might be very simple.
    there is no ground wire on the UVW side of my VFD. the manual says this for the grounding section.
    3.2.2.6 : Grounding Terminal : " Do not share the grounding terminal with zero line of power supply."
    i have no idea what that means so im scared to share the ground thats going in on my single phase power side.
    i have some images. any help would be appreciated. Thanks!
    24221
    Re: Am I Wiring this right? i have pictures.
    You should ground the frame of the motor to the service ground provided, this should be the same as the earth terminal on the power entry point.
    The +/PB is a brake resistor terminal.
    Al.
    Albert E.
    Jan 2016
    33
    thanks i will try it.
    15362
    Quote Originally Posted by a3dcreator View Post
    In this case the ( 2 ) Grounds can connect to the same Ground Terminal, or if you can find a place on the Heat sink of the VFD that has a place to mount the Ground wire, this can even be on the mounting foot of the VFD, just make sure it has a good contact, if you did it this way, remove paint or any anodizing from the Heat sink, set your parameters correct for your spindle
    Mactec54
  1. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  2. g0704 wiring pictures
    By kuyote in forum Benchtop Machines
    Last Post: 01-26-2014, 07:42 PM
  3. SX2/SC2 LMS Spindle Control Board Wiring (with pictures)
    By Nine8Six in forum Benchtop Machines
    Last Post: 08-24-2012, 05:38 PM
  4. Electronics Enclosure pictures/wiring and fusing
    By ahaidet in forum Benchtop Machines
    Last Post: 11-16-2011, 02:52 PM
  5. Need help wiring motor to driver and controller - pictures included
    By ltovey in forum DIY CNC Router Table Machines
    Last Post: 06-09-2011, 08:53 AM
