anybody out there know if the command G10 L50 (parameter change) works for fanuc control 11TT series. I tried but didn´t work and I do not if I did something wrong. neither alarm mesasage appeared nor parameter change occured.
thanks
thanks
I believe you need to specify what parameter your changing and the value you want to change it to.
Ex. this is how to load tool radius compensation from the program
G90 G10 P59 R-.002
G90 - absolute mode
G10 - load parameter
P59 - load to parameter 59
R-.002 - register value changes to -.002
hope this helps,
dave
