586,617 active members*
2,406 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas Mini Mill P-Cool problems
    Jun 2008
    18
    The programmable coolant unit on my Haas Super Mini Mill began acting up yesterday. Here are the symptoms. At first, the nozzle would swing away from its programmed position. Sometimes I could get it back to the proper position by using the 'Coolant Up' and 'Coolant Down' buttons, but these were not always reliable. As the day progressed, the problem became worse and the machine started to shut down during operations with a 'Coolant Spigot Alarm'. Today the machine wouldn't run at all, alarming out before any cutting could begin. I took the cover off the P-Cool unit and inspected the workings. Although I didn't check them with a multimeter, the micro switches seem to be properly triggered. There's no excess friction anywhere and I can easily turn the gear train by hand. Does anyone have any suggestions for fixing this?
    Re: Haas Mini Mill P-Cool problems
    I have a 2007 HAAS TM-1P that I retrofitted with a used PCOOL unit. Mine was the older style 20 position PCOOL unit.
    The PCOOL unit was broken and would not operate correctly. It would oscillate back and forth and not go to the commanded position. I received the "Coolant Spigot Alarm" similar to yours. Although the micro switch that counted the pulses looked O.K. it was broken internally. I replaced the micro switch and it has worked flawlessly for years and still going strong.
    Here is a link to the post I made on the repair.
    http://www.cnczone.com/forums/haas-m...cool-help.html
    Here is another link that has pictures that show they style of PCOOL Unit I have.
    http://www.cnczone.com/forums/haas-m...nt-nozzle.html
    HAAS PCOOL operation demonstration
    https://www.youtube.com/watch?v=wT3BwMbK4oU
    Some other videos to modifications that I made to my 2007 HAAS TM-1P that you may find useful. Note: These would be attempted at your own risk.
    Programmable Coolant Air Solenoid Introduction
    https://www.youtube.com/watch?v=B1ArxUjLy5c
    Coolant Air Solenoid Installation Part 1
    https://www.youtube.com/watch?v=Xfrhq8aCu38
    Air Coolant Installation Video Part 2
    https://www.youtube.com/watch?v=IxOgYId27tw
    HAAS TM-1P Air Solenoid Valve Utilizing M23 Relay
    https://www.youtube.com/watch?v=zssH53f_7sA
    PCOOL Installation on 2007 HAAS TM-1P CNC Mill.wmv
    https://www.youtube.com/watch?v=LWt0R58VTs0
    Hope this was of some help.
    John
    2007 HAAS TM-1P OneCNC XR5 Mill Pro. Shopbot PRT running Mach3 2010 Screen Set, Super PID and PMDX Electronics.Check out my Gallery on: http://[email protected]
    Jun 2008
    18
    Hi John,
    Thanks for your reply. You also helped me out a few years ago when I was putting in a solenoid-controlled air blast setup. Anyway, my PCool is the newer model, so the guts look quite a bit different than yours. I've got to come up with some solution other than replacing the unit, since the local Haas HFO quoted $1,600 for the part! Sure would be nice if the problem was just a microswitch.
    Thanks again,
    Bill
  1. WTB Haas mini mill
    By mtlhe in forum Haas Mills
    Last Post: 03-12-2013, 05:48 PM
  2. Looking for a Haas Mini Mill
    By medicfirearms in forum Want To Buy...Need help!
    Last Post: 10-06-2012, 03:59 AM
  3. Haas Super Mini-Mill and Haas Trunnion Table
    By Gabe Newell in forum Haas Mills
    Last Post: 06-07-2009, 07:23 PM
  4. haas mini mill
    By johnmckeown in forum Haas Mills
    Last Post: 02-19-2009, 05:26 PM
