586,103 active members*
3,258 visitors online*
    Feb 2012
    LNS Quick load
    Hello
    Ive got my old Hitachi Seiki lathe running and it has a LNS quick load bar feed attached to it but we have never used it,
    I have a job coming in which would be ideal for the is machine and bar feed would help me out on price per unit,
    But I have no manual for the control on the LNS , anyone out there got one in PDF or know where I could buy one from ?
    kind regards
    Gary
    Dec 2009
    539
    Re: LNS Quick load
    Gary,
    whats the model of the LNS. I have some - I can probably copy and send your way.
    John
    Feb 2012
    Re: LNS Quick load
    Thanks John
    its the original LNS Quick load before all the others
    look like this,
    Cheers
    Gary
    Apr 2013
    24
    Re: LNS Quick load
    I recently purchased the same bar feeder to run with my also newly purchased used hitachi seiki lathe. I have neither up and running yet however I just called LNS and they emailed me the manual for the bar feeder in PDF form. Just call them with the serial number. What hitachi seiki lathe is this being paired with?
    Actually I just found the manual in my email. If you want to PM me your email I can email it to you.
    Clinton
    Nov 2017
    19
    Re: LNS Quick load
    Hello from the future,
    I also have the same bar-feeder trying to put it on my HiTec Turn 20 sii with the Seicos Multi L (LX3) controller. I have it all wired up and actually have the M-codes the previous owner used on his lathe but the commands don't appear to do anything. It was suggested to me that you need to set a certain parameter to tell the controller it has a barfeeder now. The e-stop on the feeder stops the machine and the barfeeder knows when the spindle is running but I can't get any feed commands to work. Anyone know the parameter in question?
    Thanks in advance
  1. QUICK CNC: UA-481 with auto load & auto unload
    By bellawyl in forum Chinese Machines
    Last Post: 04-19-2014, 05:04 AM
  2. Load V.24 on Win 7 or 8?
    By JoninCO in forum BobCad-Cam
    Last Post: 01-04-2013, 06:21 AM
  3. Z load on vf-3
    By mls in forum Haas Mills
    Last Post: 05-16-2008, 04:54 AM
  4. Quick Code, Visual Quick Code
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-17-2006, 04:46 PM
