586,080 active members*
3,723 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Braking Resistor for the Fuling DZB312B005.5L2DK
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Jan 2021
    Re: Braking Resistor for the Fuling DZB312B005.5L2DK
    Hi!
    I have a DZB312B005.5L4DK and 4,5kW/24000rpm ATC HF spindle...and DC braking works well
    1. connect resistor to DC+ and BR- (i have a 100 ohm resistor)
    2. F0.20-150Hz
    3. F0.22-40%-depends of rotor and tool inertia
    4. F0.23-0,5s
    5. F0.09-25s
  2. #22
    15362
    Quote Originally Posted by LVz View Post
    Hi!
    2. F0.20-150Hz
    4. F0.23-0,5s
    5. F0.09-25s
    So he has the same connections as you do, but needs to change his Parameters settings, to suit his spindle, which is the important part, your spindle being the ATC model is most likely more robust than his spindle which he has not said what spindle he is using
    The other thing he has to determine is if his VFD Drive has the Braking Circuit some models do not have it
    Mactec54
  3. #23
    Dec 2019
    48
    Hi!
    2. F0.20-150Hz
    4. F0.23-0,5s
    5. F0.09-25s
    Hi LVz, Thanks for the suggestions! I had to back-burner this due to time issues but will look closely at your parameter suggestions ASAP.
    @mactec54, apologies for the lack of reply; I had replied but apparently it wasn't posted for some reason. Will update soon. Thanks for your help, I do appreciate it.
  4. #24
    Aug 2010
    10
    I have a DZB312B002.2L2DK and 2.2kw 18000rpm ATC spindle, 220v 10a 600hz.
    The VFD settings are very sensitive, outside a narrow range you either get no braking or an E005 over current error.
    F0.09: 7.0
    F0.20: 550Hz
    F0.22: 46
    F0.23: 5
  5. #25
    Feb 2008
    482
    Checked with fuling
    The single phase 220v models do not make use of external resistor.
    They do not close the internal brake relay .
    I set up a 6kw high speed Atc spindle
    I had to reduce deceleration time to 30 seconds or it would throw over voltage bus error on any deceleration.
    Setting brake start hz to 800 and time to 7 seconds at 30% torque seems to work on test . Stop with dc braking takes over from normal deceleration time set in 0.09
    But lowering speed during running does not use dc braking so that is using deceleration time .
    Model I have is 312 7.5kw
Page 2 of 2 12
  1. Need a braking resistor?
    By Windscreen in forum Dmm Technology
    Last Post: 05-29-2016, 04:49 AM
  2. Braking resistor wiring
    By SwampDonkey in forum Spindles / VFD
    Last Post: 05-27-2014, 07:25 AM
  3. Novakon Braking Resistor
    By iGAK in forum Novakon
    Last Post: 08-02-2013, 07:20 AM
  4. Braking resistor tip
    By LBodnar in forum CNC Machine Related Electronics
    Last Post: 05-16-2009, 01:24 PM
  5. Braking resistor question
    By Syp in forum Servo Motors / Drives
    Last Post: 01-21-2006, 04:52 AM
