586,036 active members*
3,552 visitors online*
Page 1 of 11 123
Results 1 to 20 of 251
    Jul 2013
    6
    Help with Novusun NVEM control card
    Hi all its been quite a few years and cnc builds since if been on the forum .I have in a folly purchased a motion control board to try (Novusun NVEM control card )instead of my usual ESS it is -
    CNC 200kHz Ethernet MACH3 Card Breakout Interface Board Motor Motion Controller | eBay
    I thought it looked easy to set up and install but unfortunately it is proving to be difficult and im hoping someone out there has some information that can help
    I contacted the seller at first and they have sent me a manual and a plugin for Mach 3 that I have dropped into the plugin folder
    when I start mach3 it asks if I would like to use the novusun plugin and I check the box but it will not jog, I have gone though the set up in the manual, the only thing that I cannot understand is it asks to have to PI changed in the PC if I use a network cable which I am using. What is PI? I assumed it meant IP but where would I put it and the code that is given is strange.
    It doesn't seem to see the controller?
    Any help would be appreciated
    Rod
    Dec 2009
    8
    Re: Help with Novusun NVEM control card
    You need to fix the IP address of the laptops ethernet port to something like 192.168.31.10 if you are connecting the cable directly to the Novusun.
    Unlike your Ethernet Smoothstepper that requires a fixed address, the Novusun can get its IP from the routers DHCP server.
    As long as both the Novusun and the laptop are connected to the same router an address within the same address range with be given to both devices and therefore they should be visible to each other.
    Cheers
    Nov 2014
    Hi all,
    Anyone else had the same problem ?
    I have set a static IP address of 192.168.31.10, a subnet mask of 255.255.255.0 and no Gateway.
    Laptop and controller are directly connected through a straight RJ45 cable (not crossover).
    In the Windows 10 command prompt i can see the static address using ipconfig /all
    In don't see any other IP addresses on the LAN except this one and localhost(127.0.0.1), using netstat -r
    I tried disabling Windows firewall, enabling network discovery and allowing other computers to use this laptop's network connection
    Still no joy.
    Short of using a router and letting the device figure out the addresses, is there anything else i should do ?
    Anyone else care to chip in ?
    TKS,
    -fc
    Nov 2016
    Quote Originally Posted by floodcooled View Post
    Hi all,
    Still no joy.
    TKS,
    -fc
    Hi, Disable your firewall and see if it communicates then.
    I had a very similar problem.
    Shane
    Feb 2017
    I have also purchased this controller card and I as well cannot get it to jog. I have done everything that the manual says for the setup of this board for the ports and pins and it will not jog. I have also followed all the advice that the people on this thread has given and still the jog function does not work. I have also checked and made sure that the jog function was turned on in mach3. I am running windows 10 and I have a router hooked up to the computer and the board and the router does see both devices. I have disabled ALL firewalls, windows and my antivirus programs ones. When I open Mach3 I can test my e-stop and that works and also I have tested my probe input and that also works so I think that the board and the computer are talking to each other. Any help would be appreciated, thank you.
    Oct 2016
    9
    when you start up MACH3 is the NVEM plugged into you network and powered on? In the box at the bottom of MACH3 next to the red/green reset button it should say connected to the NVEM. sorry I don't know the correct name for this box.
    Dec 2005
    594
    Hi all,
    Still no joy.
    TKS,
    -fc
    Netstat -r just shows your routing table, it won't show other active IP's on the LAN. If you are direct connecting from your computer to the controller, you probably need a crossover cable. Or, if you prefer not to use a crossover cable, you'll need to put some kind of switch or hub in between the two.
    Jun 2012
    Hi all,
    Still no joy.
    TKS,
    -fc
    Hi, with mine i threw in another ethernet card and set that ip to 192.168.31.12 and used the normal ethernet outlet for internet
    Jul 2013
    6
    Sorry it's been so long but I thought I best update this
    All I did to get it running was go into my control panel
    I can't remember we're it was but I added a extra IP address supplied in the instructions and wola it worked!
    I hope this is some help
    Jul 2020
    I still can’t get mine to connect.
    Aug 2013
    6
    try connecting thru the router and restart the computer
    Mar 2012
    231
    I was just looking over their USB version, but I'm being told ESS is the way to go...
    How is that controller working for you?
    CR
    Jun 2015
    68
    Hi all, im looking at getting one of these to upgrade my 6040 cnc. Has anyone got a copy of the manual and any info you have encounted. Id like to know before i sink money into it otherwise ill just go ESS
    Cheers Ryan
    Jan 2017
    24
    I ordered one of those NVEM boards (not received yet) and planing to replace the LPT board from my Chinese 6040 (not yet received) . I'm also interested in feedback/pointers from people who have been using this board with Mach3 and this type of CNC machine. Also if anyone has attempted to use it with LinuxCNC. Couldn't find much info about it out there. I'm a newbie with CNC so it's a steep curve :-).
    Miky
    Dec 2016
    12
    Quote Originally Posted by miky4u2 View Post
    Miky
    Also interested. Just order the Ethernet version to replace the richauto dsp on my new cnc. It just wouldn't read the usb sticks. Any suggestions on setting up and things to look out for would be great.
    Oct 2016
    9
    I am trying to set up a CNC using one of these NOVUSUN Ethernet controllers. I can't seem to figure out how to get it to work with MACH3. Everythign is attached to home network same range of IP. I confirmed the NOVUSUN is on the network by logging into my router and checking its IP. I select the NOVUSUN profile when starting MACH3 but it still doesn't seem to work. Any help, or ideas?
    TNX Jim
    Mar 2012
    231
    Quote Originally Posted by w7owc View Post
    TNX Jim
    I haven't set up a usb controller yet, but is there a plugin that Mach3 needs so it knows to send the commands there and not the parallel port?
    Oct 2016
    9
    yep, I have that plugin installed. Do I need to provide 5 volts to the enable pins of the stepper drivers? It does not show this the NVEM wiring.
    Jul 2013
    6
    Hi mate
    email me on [email protected] , I will send you the rar file for nvem if you want it
    Jan 2017
    24
    Quote Originally Posted by RODCNC1147 View Post
    Hi mate
    Towoomba ? i'm on the GC :-) You have a running CNC with the NVEM board ?
    Miky
Page 1 of 11 123
  1. Replies: 22
    Last Post: 08-02-2019, 03:05 PM
  2. DSP MOTION CONTROL CARD
    By jamienw in forum HURCO
    Last Post: 05-23-2013, 07:38 PM
  3. SMC 800 control card
    By noyloj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2009, 11:37 PM
  4. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
