587,035 active members*
3,177 visitors online*
    Jun 2014
    11
    ECP file loads invisibly in LaserCut 5.3
    I'm tearing out what little hair I have left over this. I must have corrupted this file somehow but I can't figure it out and can't describe it accurately enough to search by. I wanted to engrave a simple floor plan of my shop on some scrap plywood, along with some scale cut-outs of machines I can move around to find the optimum placement. Something happened to the file and now when I "open" it in LaserCut 5.3, all the data is "invisible". I see the "thumbnail" image when I'm selecting it from the list, but when I open it, nothing is displayed UNTIL I drag a wire frame around where the data should appear. Then it's all there, but cannot be edited. It just sits there as if it's all grouped together with one "X" in the middle of the data. If I try to "select" one element, EVERYTHING disappears again, but I can drag back through it and it's still there. I can copy and paste (everything) but again, when I try to select any one element in the copy, EVERYTHING disappears. All lines and elements are shown in red instead of the selected color for sequencing (black). Any idea what I did (for future avoidance) or how to fix what I have. I can compile and up-load to the machine, but get continual "Soft Stops" if I try to run the file. Grrrrrrrrrrrrrr!
    Jun 2014
    11
    Re: ECP file loads invisibly in LaserCut 5.3
    [Bump]STILL having this crazy problem. Can't anybody help??
    Quote Originally Posted by RedDawg View Post
    May 2017
    AAAAANNNDDD another bump, now it's happened again! Somebody MUST have experienced this before and have the fix PLEASE!
  1. Replies: 2
    Last Post: 11-07-2014, 02:15 AM
  2. Lasercut 5.3 Crashes when large file imported
    By Laser-ay in forum LaserCut
    Last Post: 02-19-2014, 06:24 PM
  3. Bearing Loads
    By jeffshaw in forum Linear and Rotary Motion
    Last Post: 09-07-2012, 03:51 PM
  4. LOADS of problems, hope you can help
    By djlee in forum Commercial CNC Wood Routers
    Last Post: 02-10-2010, 07:23 PM
  5. Lasercut 5.1 language file
    By rayscott in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-30-2008, 08:38 AM
