586,043 active members*
3,950 visitors online*
    Jul 2012
    13
    Uneven engraving mystery...
    Hello again...
    I have a mysterious issue that I cannot figure out. Any advice we be greatly appreciated.
    I am "engraving" the paint off of anodized aluminum alloy panels to create patterns and images.
    I am running into a problem where the output is uneven especially if the engraving takes more than 5-10 minutes to complete.
    I get random striping off and on throughout the piece (please see photo).
    I found that if the banding starts and I pause the engraving and then re-start it the burn is clean again for a few minutes.
    When it is banding it looks as though the laser is less bright on the surface.
    This suggests to me a possible power issue, but what kind I don't know.
    Attachment 330814
    Has anyone seen anything like this?
    The example was engraved at a speed of 100mm/s at 50% on a 40w chinese co2 laser.
    Thanks!
    Nov 2020
    Re: Uneven engraving mystery...
    Hello. I faced the same problem. Tell me, did you manage to solve it? If so, how?
    Jan 2008
    940
    Your piece may be heating up causing the striping
  1. Engraving on uneven surface (OAR/Paddle face)
    By Minora72 in forum WoodWorking Topics
    Last Post: 07-08-2016, 06:24 AM
  2. PROBLEM - Uneven engraving from left to right
    By Lunder in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-13-2015, 11:33 PM
  3. GADJ - Tool for Engraving Uneven Surfaces
    By jblakey in forum G-Code Programing
    Last Post: 04-24-2014, 01:04 AM
  4. Uneven traven
    By CEStanley in forum Benchtop Machines
    Last Post: 12-23-2012, 05:09 PM
  5. Engraving and uneven surfaces
    By phatjap in forum DIY CNC Router Table Machines
    Last Post: 04-21-2010, 01:11 PM
