586,116 active members*
3,469 visitors online*
IndustryArena Forum > CNC Electronics > Leadshine > Issues with Mach3 and M542T drivers
Results 1 to 6 of 6
    Nov 2011
    7
    Hello,
    I am having issues getting my motors to run correctly with Mach3, but I get the feeling it's a stepper driver issue. I have an old Fireball V90 that I finally decided I would wire up. I grabbed a 3-axis kit from OMC stepper online that includes the M542T drivers that are apparently designed by Leadshine. Link here: https://www.omc-stepperonline.com/cn...2t-23hs45.html
    I have 5TPI double-start leadscrews on X and Y. With microstepping set to 400 step/rev, I wager that I should have 2000 steps per unit in Mach3. To my surprise, however, X and Y are moving at TOTALLY different rates. This is in spite of the fact that both axes have the same settings.
    Any thoughts on this issue? I am an electrical engineer with experience troubleshooting automation equipment, but this has been a humbling experience to say the least. I have attached a video and my dip switch settings for reference, along with that manual page.Tapatalk Cloud - Downlaoad File VID_20180315_194715.mp4
    Sent from my Nexus 6P using Tapatalk
    Apr 2004
    733
    Open up the drive and check switch continuity or bad solder joint.
    Swap drives and see if the problem follows the drive.
    Exact same stepper motor? If it isn’t, make sure both are same steps/degree. Most common are 1.8degree but there are .9degree also available.
    Is the acceleration set the same on both axis? Looks like the gantry is set higher.
    Nov 2011
    7
    Re: Issues with Mach3 and M542T drivers
    Quote Originally Posted by jfong View Post
    Good idea on switching the drives. I will give this a shot. I should be able to touch up a solder joint if that's the issue.
    These are the same steppers and the acceleration is the same.
    Apr 2004
    733
    Once you figure it out...
    Always better to run higher microstepping then the half step you currently using. I use atleast 8microsteps. Gives less low speed motor vibration.
    Try to run higher drive voltage. It will give better torque vs rpm performance. The drives are rated at 50v but it’s best not to run it too close to max. 36-42volts would be good.
    Nov 2011
    7
    You were right on the money. It was a bad driver. Swapping in a replacement fixed the issue I was having. Now to get everything dialed in...
    Like this, Nice idea
  1. XHC Mach3 4-axis control card with M542t drivers and Nema 24 stepper motors
    By usajet in forum CNC Machine Related Electronics
    Last Post: 12-04-2016, 03:02 AM
  2. Replies: 0
    Last Post: 12-04-2016, 03:00 AM
  3. Replies: 0
    Last Post: 12-04-2016, 02:51 AM
  4. G540 Mach3 Display Issues & Slave Axis Issues
    By umustsurf in forum Gecko Drives
    Last Post: 09-30-2011, 03:23 AM
