586,075 active members*
4,044 visitors online*
    Nov 2004
    26
    GMFC help needed
    Hi, All
    I just finished my cnc foam cutter and have it running on foamworks
    well. I am deciding what software to purchase and am now trying GMFC.
    I have it running but after it makes a cut it dose not return to the
    zero point on the Y axis. After each cut it gets lower and lower and
    is repeatable. Dose anyone have any ideas.
    Gary
    Feb 2006
    40
    I would normally expect it to get higher as you lose steps when the direction reverses. Do you have a figure in the "steps lost" field under table configuration?
    EB
    Nov 2004
    26
    Quote Originally Posted by Sleedo View Post
    EB
    Eb,
    It is "0" It might be loosing steps but the error is so repeatable. If I block cut it returns to the correct "0" position. I am running 400 steps per rev with a 16tpi screw.
    I am going to load CeNeCe tonight.
    Gary
    arman Guest
    hi,
    for my case, setting motor too fast will cause out of shape. with slow setting it solve the problem. try lower your steps/mm value to half.
    arman
    May 2003
    162
    check your printer port mode as well(EPP, ECP, SPP)
  1. New to this help needed!
    By Coolcuttings in forum Hobby Discussion
    Last Post: 12-16-2006, 05:53 AM
  2. Help needed
    By widgitmaster in forum Community Club House
    Last Post: 12-17-2005, 10:27 PM
  3. Help needed
    By BlackIbanez in forum G-Code Programing
    Last Post: 11-23-2005, 08:22 PM
  4. New VMC needed
    By Scott_bob in forum Uncategorised MetalWorking Machines
    Last Post: 08-22-2004, 06:19 PM
  5. what is needed for cnc
    By kenlambert in forum CNC Machine Related Electronics
    Last Post: 02-03-2004, 02:59 PM
