586,089 active members*
3,862 visitors online*
Results 1 to 3 of 3
    Nov 2015
    8
    Lab Volt 5600 serial/null modem cable
    I have a Lab Volt 5600 and the serial cable has one of the connectors pulled off I am not sure what type of cable it is or the wiring diagram for it. Both sides were db9 female connectors. The cable has 8 wires and on each end pin 6 is opened, all the other pins were soldered. It does seem to have had any loops. Anyone have any idea what type of cable it is or does anyone have the pin layout for it the mill is from the 2003-2004 period I believe it is running version 3 firmware.
    Jul 2017
    348
    Labvolt requires null modem serial cable
    UOTE=Goover;1926264]I have a Lab Volt 5600 and the serial cable has one of the connectors pulled off I am not sure what type of cable it is or the wiring diagram for it. Both sides were db9 female connectors. The cable has 8 wires and on each end pin 6 is opened, all the other pins were soldered. It does seem to have had any loops. Anyone have any idea what type of cable it is or does anyone have the pin layout for it the mill is from the 2003-2004 period I believe it is running version 3 firmware.[/QUOTE]
    Jul 2017
    348
    Re: Lab Volt 5600 serial/null modem cable
    Serial null modem cable
  1. Help with a Lab-Volt 5600 D&M 6c CNC Milling Machine and Computer
    By darkexphos1 in forum Benchtop Machines
    Last Post: 12-17-2015, 03:04 PM
  2. Help with a Lab-Volt 5600 D&M 6c CNC Milling Machine and software.
    By darkexphos1 in forum Want To Buy...Need help!
    Last Post: 03-25-2015, 02:39 AM
  3. 160i-L null cable
    By Daka101 in forum Fanuc
    Last Post: 05-04-2012, 02:30 AM
  4. Pinouts for 9p to 25p No null modem
    By EliteCustoms in forum Fadal
    Last Post: 08-02-2010, 02:03 PM
  5. Null Modem Question
    By bz1801 in forum DNC Problems and Solutions
    Last Post: 02-21-2006, 03:20 PM
