586,058 active members*
4,560 visitors online*
    Nov 2015
    8
    Lab Volt 5600 post processor
    I have a Lab Volt 5600 which is running version 3 firmware the mill is I believe from the 2003-2004 time period. The mill runs fine in manual mode so I believe I have a working controller but I do not have the software however there are post processor available does anyone know what I would need to get it working with some other cam software this is my first mill. from the manual its not clear if I would need a dongle or not it might need one to run with the lab volt software would it need one to work with a post processor as well?
    file:///C:/Users/userX/Downloads/CNC%20Post%20ProcessorsRev06212010%20(7).pdf
    Jul 2017
    348
    Re: Lab Volt 5600 post processor
    Hi
    did unever get software to run the labvolt cnc...i have 3 old labvolt machines with no software and need some help
    QUOTE=Goover;1926270]I have a Lab Volt 5600 which is running version 3 firmware the mill is I believe from the 2003-2004 time period. The mill runs fine in manual mode so I believe I have a working controller but I do not have the software however there are post processor available does anyone know what I would need to get it working with some other cam software this is my first mill. from the manual its not clear if I would need a dongle or not it might need one to run with the lab volt software would it need one to work with a post processor as well?
    file:///C:/Users/userX/Downloads/CNC%20Post%20ProcessorsRev06212010%20(7).pdf[/QUOTE]
    Jul 2017
    348
    i was able to get level 3 level4 and level 5 software
    and on my machine level 4 software works and i ran a test program from preloaded sample gcode files and it ran great..it took me 1 yr to get to this point..it was very difficult getting the 3 old machines i have in working order since labvolt went out of business and festo took oever and they arent familiar with the older machines
    - - - Updated - - -
    Jul 2017
    348
    Labvolt post processors for gibbscam mastercam and edgecam on their website .u dont need a dongle but u do need labvolt mill v4 or v5 to b able to communicate with machineTE=Goover;1926270]I have a Lab Volt 5600 which is running version 3 firmware the mill is I believe from the 2003-2004 time period. The mill runs fine in manual mode so I believe I have a working controller but I do not have the software however there are post processor available does anyone know what I would need to get it working with some other cam software this is my first mill. from the manual its not clear if I would need a dongle or not it might need one to run with the lab volt software would it need one to work with a post processor as well?
    Dec 2010
    6
    Hello Shelby5041,
    I've been PM'ing you about the LabVolt Level "X" software, but your Private Message Inbox is full so I can't reply until you delete some of the messages in your inbox.
  1. Lab Volt 5600 serial/null modem cable
    By Goover in forum USB, RS232, PARALLEL etc
    Last Post: 11-29-2019, 02:32 AM
  2. Reed Switches 5-120 DC 5 volt or 24 volt power supply?
    By ballistic42 in forum Benchtop Machines
    Last Post: 01-12-2016, 09:09 PM
  3. Help with a Lab-Volt 5600 D&M 6c CNC Milling Machine and Computer
    By darkexphos1 in forum Benchtop Machines
    Last Post: 12-17-2015, 03:04 PM
  4. Help with a Lab-Volt 5600 D&M 6c CNC Milling Machine and software.
    By darkexphos1 in forum Want To Buy...Need help!
    Last Post: 03-25-2015, 02:39 AM
  5. 60-volt Keling servos with 65-volt power supply....no go??
    By uawgmsmco in forum Servo Motors / Drives
    Last Post: 11-09-2013, 05:22 PM
