586,058 active members*
4,449 visitors online*
    May 2006
    20
    Calling plugin via button?
    I've activated the webcam plugin in UCCNC and would like to activate the plugin via a button on the run screen rather than having to go thru the config/general/plugins/show route. Is that possible? Ideally I'd like to be able to specify the location and size of the popup screen but that's not necessary. Just getting it to activate by a button would be great.
    Apr 2014
    215
    Re: Calling plugin via button?
    Yup it is possible...
    through calling a macro:
    Function: void Pluginshowup(string Pluginfilename)
    Description: This function calls a Plugin file's Showup_event(); function. This is useful when the plugin should do something on a button press event, forexample when it should show it's GUI interface.
    Example: exec.Pluginshowup("Plugintest.dll");
    Not sure if it's in the present release but it will be available shortly.
    Rob
    Oct 2005
    1145
    Yes PluginShowup() works now. You would create it in a Macro inside the series of macros assigned for buttons (m20000 - m20999) then you can assign that macro to a button on screen.
    Robert is paying better attention than I am (;-) . I must be slowing down.
    (;-) TP
    Apr 2014
    215
    Quote Originally Posted by vmax549 View Post
    (;-) TP
    .... ahh but I'm only answering 1/2 the question missed the button macro bit.... oops....
    rob
    May 2006
    20
    robert and vmax549, thanks for the quick response. I had assumed there would be a way to do it. Great to have such helpful members here. Regards.
  1. Xbox360 Controller Plugin Macros/Button Assignments
    By Wolfspaw in forum Mach Wizards, Macros, & Addons
    Last Post: 05-09-2014, 01:44 AM
  2. Calling a Tool up
    By MBG in forum G-Code Programing
    Last Post: 04-30-2008, 03:04 AM
  3. Calling all machinist!
    By MattF811 in forum Employment Opportunity
    Last Post: 10-29-2007, 08:42 PM
  4. Help with calling a subroutine
    By hindocarina in forum Mach Mill
    Last Post: 02-12-2007, 04:32 AM
  5. Calling All Richmonders!
    By Robyn in forum Trade Shows / Webinars / Other Events
    Last Post: 06-05-2006, 01:24 PM
