586,393 active members*
2,854 visitors online*
Results 1 to 2 of 2
    May 2006
    20
    Help measuring latency and jitter
    I have a Stepcraft 2-600, a UC100 parallel-to-USB converter, and UCCNC running under Win10 on a MacBook Pro (bootcamp not Parallels). I designed a small project (a 4" coaster) that came out at a bit over 3.5". Everything was shrunk. How do I measure latency and jitter on my system? I've seen some posts of those that have done this on Linux and also using a feature in Mach3, but I can't find how to do this either on Win10 or in UCCNC. Any help would be appreciated as I'm at a loss on what the problem is. I'm did the design in VCarve Pro, but too many folks use this program to have that to be the problem. I use VCarves Mach2/3 Arcs (mm) postprocessor which is what others with a Stepcraft and UCCNC all use.
    Jun 2015
    943
    Re: Help measuring latency and jitter
    Quote Originally Posted by loesch View Post
    I think you mistaken of terms latency and jitter with axis resolutions and movement distances.
    There is no jitter and latency measurement in UCCNC.
    The latency means how fast your motion controller can communicate with your LPT port.
    There is no LPT port in UCCNC. unlike with Mach3 and linuxcnc the motion is generated not on your computer, but on an external device.
    Jitter means how much the control pulses differs from optimal, again no need to measure that,
    because they are generated not by the computer.
    If your workpiece came out shrinked then you should check 2 things:
    1.) Check if your steps per unit is defined correctly in the UCCNC.
    You can check this with moving your axis a known distance and measure how much it traveled,
    if it moved more or less than you commanded then adjust your steps per value.
    Do this until the distance you move will be the same you measure.
    2.) Check your g-code program, the path size the CAM program output.
    The easiest way is to create a very simple object, for example a single square shape.
    Check the size of that object in your g-code.
    Because you defined that square to a known size it should have the same size in your g-code, you can verify it easily.
    If it is not output the same size then there is a problem in your post processor or your units settings in your CAM,
    adjust it to get the correct size output in g-code.
  1. DRO-350 Scale Jitter
    By Nateg281 in forum Benchtop Machines
    Last Post: 03-17-2011, 07:25 AM
  2. Jitter in the signal
    By AlainB in forum CNC Machine Related Electronics
    Last Post: 03-01-2010, 09:05 AM
  3. New Pc Parallel port jitter
    By Jordan T in forum Computers / Desktops / Networking
    Last Post: 01-06-2010, 05:34 AM
  4. When do you stop measuring rapids in IPM and start measuring in G?
    By slashmaster in forum Benchtop Machines
    Last Post: 07-08-2009, 10:42 PM
  5. Driver Test Q! - How much jitter is acceptable?
    By arifbustani in forum Mach Software (ArtSoft software)
    Last Post: 02-08-2009, 01:46 AM
