Hey folks
I'm working on a cnc conversion using gecko 320x's and have run into a problem.
Going through the helpful starting up steps, I've reached connecting the motor, the servo at this point will only rotate counter clockwise, about 1/20th or so of a turn at a time, it doesn't respond at all to manually turning the servo (nor does it seem to be resisting being turned) the gecko 320x just reads solid fault.
Backing up, I've gone through the encoder tests once again and it passed, its passed all the previous tests.
Reading through the manual again, the fault conditions don't seem to be relevant, the only one which "could" be possible is the motor is pulling too much startup current but with it not installed on anything and connected to a 20a power supply that doesn't seem likely either.
Any ideas on how to proceed?
