586,112 active members*
3,102 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Acramatic 950 " System Failure 01026 " upon startup
Results 1 to 7 of 7
    Aug 2016
    Question Acramatic 950 " System Failure 01026 " upon startup
    Upon start up and machine has gone through its routine, I get a message "System Failure 01026"
    After going through the diagnostic procedure using switches #1 & #4 on the BOH board I get error messages:
    cpu board serial link is absent on 3 boards
    cpu board math chip is absent on 2 boards
    I have been looking for info that tells me what the leds on each of the boards indicates. This has been a great help in diagnosing what board is faulty in the past.
    Thank you in advance for any help.
    Brian
    Dec 2007
    28
    Is this a maxim or magnum?
    Aug 2016
    Re: Acramatic 950 " System Failure 01026 " upon startup
    Maxim
    Dec 2006
    584
    Did you get into the TOOLBOX and look at each board?? Did you get any type of power surge?? Have you looked at all the voltages on the power supply with a meter??
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Oct 2005
    169
    Brian - were you able to get this resolved?
    We got this same error today. The machine was running and the operator accidently hit the power off button instead of the feed hold button. Now when it boots we get System Failure 01026. The manual just says "Divide Exception" but it does not discuss how to remedy. It looks like a parameter issue to me but I really have no Idea where to go with this.
    Oct 2005
    169
    Just ran the continuous diagnostics and here are my screen shots.
    Attachment 340218
    Oct 2005
    169
    Fixed - I called "Fives" and got a procedure sheet called "Procedure to Initialize System Retained Data and Servo Configuration Data" I would post it but not sure if there would be some copyright issue. Basically needed to reinitialize sector 208 and 336 in the memory chunk table.
  1. Replies: 0
    Last Post: 05-22-2015, 09:00 AM
  2. Fanuc 18i- MA "Not Ready" on startup!
    By John Keats in forum Fanuc
    Last Post: 09-16-2014, 10:20 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. 8040M "Transmission Failure" message
    By m1911bldr in forum Fagor Automation
    Last Post: 01-12-2011, 10:49 PM
  5. Vertical system "jerks" and "bangs"??
    By REVCAM_Bob in forum Servo Motors / Drives
    Last Post: 06-12-2006, 03:09 PM
