586,060 active members*
4,409 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Alarm 090 Reference Return Incomplete
Results 1 to 7 of 7
    Jun 2007
    84
    The battery for the X/Z axis controller died and now I get a message:
    300 X Axis needs Zero Return
    300 Z Axis needs Zero Return
    When I try to ref return the axis, I get 090 Reference Return Incomplete
    Doosan Puma TT1800SY with Fanuc 18i-TB control
    Feb 2013
    788
    Re: Alarm 090 Reference Return Incomplete
    First: check the battery levels for the drives in question.
    Second: are you setting the APC reference for the appropriate drive? The TT1800 is a 2 path machine...you might be setting the upper path when the lower path is the one in alarm.
    Third: review that you are doing it correctly.
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Jun 2007
    84
    It was the battery for the upper turret.
    Replaced the battery, btu can't ref return the X/Z axes.
    Not sure how to set the APC reference.
    Do you have any documentetion?
    Feb 2013
    788
    The 300 alarm means that you need to set the APC (absolute position coder) reference position, because the battery died and the number is no longer held in memory.
    Note to self: Replace batteries at least once a year...or worst case, when the battery warning occurs.
    Look for the instructions for "APC 300 Alarm on a lathe
    How to reference home with an Absolute Position Coder (APC)"
    On this page: http://www.cnczone.com/forums/daewoo...bulletins.html
    Aug 2016
    29
    Hey, Don.
    I run 3 Nakamura WTs with the 18i controller. Very similar to your Doosan. I've had the same problem as you're having. I have the documentation on how to reset your axes (at least it works on our Nakamuras). Send me an email or fax number and I'll get it to you. Since they're both 18i controllers, you might want to give it a try.
    Aug 2016
    29
    Hi Dhardt.
    I just read your service bulletin for resetting the "APC 300" alarm on a Doosan. It's MUCH easier on your Doosan than on my Naks.
    Jun 2007
    84
    Thanks again Darryl
    You are the best.
  1. APC manual reference position return HELP Please
    By LaserRSTAWD in forum Fanuc
    Last Post: 04-18-2014, 02:53 PM
  2. Deco 10 swiss screw machine. return to reference point alarm 224 S1 spindle
    By Braingauge in forum CNC Swiss Screw Machines
    Last Post: 10-31-2013, 06:36 PM
  3. Reference return incomplete
    By Leha_Blin in forum Fanuc
    Last Post: 08-17-2011, 04:22 AM
  4. G30(reference point return)
    By Reg wharton in forum Daewoo/Doosan
    Last Post: 06-13-2008, 11:32 AM
  5. Return through reference point?
    By RBrandes in forum Haas Mills
    Last Post: 12-02-2005, 04:49 PM
