586,076 active members*
3,669 visitors online*
Thread: Alarm 367?!
    Jan 2007
    51
    Alarm 367?!
    I was machining a part on our Vf-2 yesterday and everything was going finr then when it went to do the finish pass and alarm came up and said "cutter compensation interference" #367. what does this mean? is there a problem with our new machine or is there a problem with the programmer(me)?
    Aug 2005
    578
    My VF book sez that the G01 can not be done with cutter size. Therefore I gotta think that you are using comp in the control and inputting a dia in the geometry page and that the G01 value at your lead in is less than teh radius of the tool.
    Personaly I use wear comp so that I don't put a value in the dia on the geo page and when I comp it's a +or - small number.
    Jan 2007
    51
    thanks
  1. Amp Alarm
    By bbrreid in forum CNC Machine Related Electronics
    Last Post: 03-01-2012, 12:13 AM
  2. 205 p/s alarm
    By bink in forum Fanuc
    Last Post: 12-09-2006, 04:04 AM
  3. alarm #180
    By j-radkemachine in forum Haas Mills
    Last Post: 07-20-2006, 07:34 PM
  4. Ps-012 Alarm For T15
    By Mircea in forum G-Code Programing
    Last Post: 06-15-2006, 05:01 AM
  5. Alarm 160
    By quatturbo in forum Haas Mills
    Last Post: 02-26-2006, 07:27 PM
