586,069 active members*
3,389 visitors online*
    Sep 2008
    325
    Anyone else notice this?
    I had used the conversational on my lathe to do an 'internal' NPT thread recently and it worked fine. Then last night I switched to do the same NPT thread as an 'external' thread. I clicked the external button and the appropriate light lit up however when I went to run the program I noticed that the angle was still for an internal thread on the tool path display. I went back into the conversational and clicked the button back and forth between external and internal and reposted the program with the same result. I even went back into the conversational and selected a different size external thread and then went back to the size I needed and no luck. I had to actually go into the program that was created and change the parameter for the canned threading cycle manually to get it to cut the external thread.
    I know the external thread conversational function works because I had cut external threads before using it. However, this did happen once before where I cut an internal NPT thread and the thread pitch and diameter was correct but it was set to cut a straight thread. At that time I just figured I screwed up when I was setting parameters in the conversational screen. But when I couldn't get it to work last night regardless what I tried it got me wondering.
    Jul 2015
    27
    Re: Anyone else notice this?
    What PP version?
  1. Exhibition notice
    By roctech in forum Roctech CNC Routers
    Last Post: 06-17-2012, 12:50 AM
  2. A-CNC-G NOTICE
    By rgee in forum Australia, New Zealand Club House
    Last Post: 08-26-2009, 09:41 AM
