586,035 active members*
3,666 visitors online*
    Oct 2005
    420
    EZ-Path Software Version 2.50.45
    Hello,
    Does anyone have EZ-Path software version 2.50.45 currently running on their machine? When I purchased my lathe it was installed, but the hdd became corrupted before I could make a successful backup. The latest version EMI sells is 2.50.21, which I'm currently running. I would like to go to the 2.50.45 or later to fix(or try to) some other issues I'm having. I believe all I need is the EZPATH.EXE file, but the BMDC.BIN would be nice as well. For that matter EZPUTILS.EXE.
    Trying to get the machine to actually send/recieve via RS232 consistently and without locking up my machine.
    Shoot me a PM, I know this stuff costs money, I don't expect a freebie.
    Dec 2013
    28
    Re: EZ-Path Software Version 2.50.45
    I have all the EZpath software and DOS. I will see what version it is. For $30 i replaced the diskette drive with a usb interface and use a thumb drive to load files. Works great. Also the EZpath will run generic gcode in .txt format as long as every line has both axis positions in them and a feed rate.
    Oct 2005
    420
    Hi Machinehead,
    Thanks for the response. Would be very interested to see what version software you have. If you could check it out when you can and get back to me would greatly appreciate it.
    Nate
    Oct 2005
    420
    Machinehead,
    Did you ever get a chance to check out what version you had?
    Jul 2010
    7
    Quote Originally Posted by Machinehead57 View Post
    i need the ez-path II software installer... can you help me???
  1. change the version of software
    By belsasar in forum Haas Mills
    Last Post: 03-16-2016, 12:44 PM
  2. Replies: 3
    Last Post: 08-17-2015, 05:35 PM
  3. Fanuc software version?
    By landslide1 in forum Fanuc
    Last Post: 10-06-2013, 10:18 PM
  4. KM3-P software version?
    By centuryz in forum HURCO
    Last Post: 06-04-2010, 06:04 AM
  5. Fanuc 10 11 software version
    By greenery_fr in forum Fanuc
    Last Post: 01-07-2009, 01:56 AM
