586,388 active members*
3,349 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Thoughts on the Basic Machine Stand
Results 1 to 6 of 6
    Feb 2007
    27
    Hi!
    Are there any basic machine stand users out there? Can anyone offer any reviews? I'm ready to purchase the 1100 but the larger stand is a bit of a problem for me. I'd like to make sure that the basic (which is smaller) machine stand will work.
    Thanks!
    Matt
    May 2005
    1810
    You looking to buy or build?
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Feb 2007
    27
    Stand
    This is purchasing their new "basic" stand as opposed to the larger one that they sell with the coolant pump.
    Matt
    Mar 2006
    9
    Something that would be great on a Tormach stand....
    I have the deluxe stand and it is too tall. It would really be nice when having to reach back into the stand for cleaning, adjusting or whatever if it was a few inches shorter.
    Jeff
    Dec 2006
    13
    The Tormach web site says that the new deluxe stand is lower.
    http://www.tormach.com/Product_PCNC_stands.html
    Nov 2006
    592
    From what I can see from looking at the pictures, it looks like the basic stand uses the same machine base as the deluxe. I have the deluxe. The machine base is a welded box construction, with tap pads welded on to the top surface, then machined flat. It has adjustable feet on the bottom, and is very sturdy. The picture shows the same cabinet construction from what I can see, so there is a handy enclosure on one side for the computer, and another in the front for tools or whatever. If they are the same, then there would also be another door on the other side where the coolant tank resides in the deluxe model.
    As far as 'will it work' .... well, it is the ideal base for the machine. It's plenty heavy and sturdy. The difference is in how you want to catch the chips and/or coolant that will be flying around. Even with the deluxe, I'm doing a few mods for containment. If you have limited space, I'm sure you can guide the chips into the smaller pans with whatever you have available.
    Hope that helps,
    --97T--
  1. thoughts on an X Y A machine design
    By bfreedland in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 08:17 PM
  2. Low cost idea for machine ways. Thoughts?
    By jstuedle in forum DIY CNC Router Table Machines
    Last Post: 06-29-2006, 01:05 AM
  3. Possible new machine - thoughts?
    By Mike F in forum DIY CNC Router Table Machines
    Last Post: 11-09-2004, 12:23 AM
  4. My first CNC machine... thoughts?
    By telmnstr in forum DIY CNC Router Table Machines
    Last Post: 10-16-2004, 04:22 AM
  5. What does CAD/CAM stand for?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 08-17-2004, 12:40 AM
