586,390 active members*
3,003 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Okuma And Howa Act 5 Lathe
Results 1 to 2 of 2
    Oct 2015
    17
    I have an Okuma & Howa Act 5 CNC lathe and am stuck with a problem with the hydraulics. Yesterday the chuck worked perfectly fine, would open and close but unknown whether the tail body worked. Today while running the tail body would not advance, neither would the tail stock with the foot pedals and the chucks will not open either. I checked and there is hydraulic pressure but nothing is working the requires hydraulics.
    Please help as I am losing manufacturing time.
    NorthMachinist
    Jun 2004
    511
    Re: Okuma And Howa Act 5 Lathe
    I would check your outputs, and wire connections. That many things that are not working have a common cause.
  1. Okuma And Howa Act 5 Lathe
    By NorthMachinist in forum Okuma
    Last Post: 06-10-2022, 10:32 PM
  2. Replies: 0
    Last Post: 11-18-2015, 10:49 PM
  3. Okuma Howa CNC Lathe
    By gearmachinist in forum Okuma
    Last Post: 04-25-2014, 02:17 PM
  4. need post okuma howa lathe
    By mike10 in forum Post Processors for MC
    Last Post: 07-03-2010, 04:33 AM
  5. need help okuma howa lathe
    By mike10 in forum CNC Tooling
    Last Post: 09-17-2006, 02:10 AM
