Hi Guys I have an idea for a new feature for UCcnc. It is called WizardCam. It will be a feature where you can use any number of MacroWizards to create a Master file of an entire part. The trick is there is NOT a set number of wizaeds that you can use . ANYONE can write a MacroWizard to be used with teh WizardCam feature. There is about 8 lines of code that HAVE to be in teh script for teh macroWizard to be compatible with WizardCam.
Teh Macro Wizards could STILL work the same way as a normal Wizard in that is would create a single Gcode file based on teh wizards features just like normal. There would be a Checkbox to select from MacroWizard output to WizardCam output.
There are conversational packages out there BUT you are limited to THEIR way or the Highway . IF they did not do teh function as you wanted you are out of luck . And NONE give you the choice to use OTHER wizards with their package .This way you can create or download a Macro Wizard make by anyone to use with your work.
Also you could have UNLIMITED features and functions to work with.
At any time you can edit teh temp file to make any corrections you require .
ONE thing is though YOU must assemble your features in teh correct order because there is no easy way to reorder teh assembly of teh complete program but you can make adjustments as you go with EDIT.
UCCNC added in some neat features to the NEW macro format that makes it fantastic to work with and has a LOT of Horsepower to work with. (;-)
SO what do you think ? Something you might be interested in ??
I already have my version running it will be up to UCCNC to included a version for you.
(;-) TP
