586,117 active members*
3,488 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > 4 axis cnc diy hotwire cutter (raspberry pi?)
Results 1 to 2 of 2
    Aug 2016
    3
    trying to build a cnc hotwire cutter. i dont know if its possible to just use raspberry pi but i haven't seen any software for it(cnc software). if i had to use arduino, is it possible to directly connect the uln2003 driver on the data port of the arduino? if so, is there a software for it to control the driver for 4 axis cnc cutting? i ask because everytime i search for arduino cnc they always have the cnc shield that you add to the board to control nema stepper motors. i just want to use the 28byj-48 stepper motor(cheap!). im not proficient in python programming or any programming so i would just prefer to download the software necessary and import the airfoil profile to start cutting foams.
    the only sort of programming i did for the python script to run/test the stepper motors was downloaded from a "running stepper motor with raspberry pi" and edit it to suite my needs(ie. the right gpio port. all for 4 stepper motors).
    https://youtu.be/9QOPaNi4q3o
    Code:
    import RPi.GPIO as GPIO
    import time
    GPIO.setmode(GPIO.BOARD)
    ControlPinX1 = [7,11,13,15]
    ControlPinY1 = [16,18,22,29]
    ControlPinX2 = [31,33,35,37]
    ControlPinY2 = [32,36,38,40]
    for pinX1 in ControlPinX1:
        GPIO.setup(pinX1,GPIO.OUT)
        GPIO.output(pinX1,0)
    for pinY1 in ControlPinY1:
        GPIO.setup(pinY1,GPIO.OUT)
        GPIO.output(pinY1,0)
    for pinX2 in ControlPinX2:
        GPIO.setup(pinX2,GPIO.OUT)
        GPIO.output(pinX2,0)
    for pinY2 in ControlPinY2:
        GPIO.setup(pinY2,GPIO.OUT)
        GPIO.output(pinY2,0)
    dir1 =[ [1,0,0,0],
                [1,1,0,0],
                [0,1,0,0],
                [0,1,1,0],
                [0,0,1,0],
                [0,0,1,1],
                [0,0,0,1],
                [1,0,0,1] ]
    dir2 =[    [0,0,0,1],
                [0,0,1,1],
                [0,0,1,0],
                [0,1,1,0],
                [0,1,0,0],
                [1,1,0,0],
                [1,0,0,0],
                [1,0,0,1] ]
    dir0 =[    [0,0,0,0],
                [0,0,0,0],
                [0,0,0,0],
                [0,0,0,0],
                [0,0,0,0],
                [0,0,0,0],
                [0,0,0,0],
                [0,0,0,0] ]
    for cycle1 in range(2560):
            for halfstep in range(8):
                for pinX1 in range(4):
                    GPIO.output(ControlPinX1[pinX1], dir1[halfstep][pinX1])
                    for pinY1 in range(4):
                        GPIO.output(ControlPinY1[pinY1], dir1[halfstep][pinY1])
                        for pinX2 in range(4):
                            GPIO.output(ControlPinX2[pinX2], dir1[halfstep][pinX2])
                            for pinY2 in range(4):
                                GPIO.output(ControlPinY2[pinY2], dir1[halfstep][pinY2])
                    #time.sleep(0.0000001)
    for cycle2 in range(2560):
                    GPIO.output(ControlPinX1[pinX1], dir2[halfstep][pinX1])
                        GPIO.output(ControlPinY1[pinY1], dir2[halfstep][pinY1])
                            GPIO.output(ControlPinX2[pinX2], dir2[halfstep][pinX2])
                                GPIO.output(ControlPinY2[pinY2], dir2[halfstep][pinY2])
         GPIO.cleanup()
    May 2006
    84
    Re: 4 axis cnc diy hotwire cutter (raspberry pi?)
    For Arduino based CNC, check out grbl
    There are a number of simple shileds that are suppoted by grbl. cncshield is one. Available from protoneer's eBay shop or from 3dtek.xyz
  1. CNC Hotwire Foam Cutter For Sale - where to post?
    By blake374 in forum CNC Wire Foam Cutter Machines
    Last Post: 04-02-2014, 03:55 PM
  2. NewCnc hotwire cutter 0 footprint
    By alans in forum News Announcements
    Last Post: 05-17-2012, 09:11 PM
  3. Solidworks to HotWire cutter?
    By jlcortes in forum CNC Wire Foam Cutter Machines
    Last Post: 12-26-2010, 05:19 AM
  4. Hotwire Foam Cutter
    By paprjam in forum Casting Metals
    Last Post: 03-23-2009, 05:45 PM
