586,112 active members*
3,045 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Control Software > LaserCut > LaserCut 6.1 Error "C0000005" when "Download Current CFG"
    Aug 2016
    Dear People,
    I just got a laser engraving machine from China, and it came with the software LaserCut 6.1.
    I installed it on a PC running Windows 7, 64 Bit.
    I get an error "C0000005" when I click the "Download current CFG" to send the file to the engraving machine. This error crashes the software...
    I installed it on a laptop with Windows 7, 64 Bit, and it worked fine.
    Anybody have any idea how I can proceed? I need it to work from the PC
    Oct 2011
    69
    Re: LaserCut 6.1 Error "C0000005" when "Download Current CFG"
    i am also running lasercut 6.1 i just reinstalled the program I am also running windows 7 64 bit no issues did you ever figure out how to setup a rotary as i dont know how if you did can you pass on any help thanks
    Aug 2016
    Quote Originally Posted by DJNPHOTO View Post
    Even though I bought the engraver with the rotary, I have not tried using it till now. In case I do, I will let you know.
    By the way, on another topic, I found this link very useful to adjust the engraver in case it is not cutting to the right size:
    https://www.i3detroit.org/wi/images/...nateManual.pdf
    Sep 2020
    I am having the same problem but with Windows 10. Have you managed to solve the problem?
  1. Replies: 5
    Last Post: 01-12-2014, 07:07 PM
  2. Replies: 2
    Last Post: 06-19-2013, 05:40 PM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
