586,058 active members*
3,950 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Help me identify this lead screw size
Results 1 to 10 of 10
    Sep 2007
    160
    Hi Guys,
    I recently strip the cross nut on my manual 3in1 lathe/mill and I can't find the replacement part from the manufacture... unfortunately... It's a Bolton Tools AT520 12" x 20" Combo Lathe/Mill | AT520 . But they don't stock that part any more and I can't find any info on the lead screw to buy a replacement or make one.
    I need to identify the screw size/pitch... so maybe I can find a nut that can fit it or threaded one myself??? Is that possible? Can I get a tap that's the right size and just tap it like a normal screw?
    Attached picture and sizes.
    thank you.
    Attached Thumbnails Attached Thumbnails IMG_9125.jpg   IMG_9126.jpg   IMG_9127.jpg   IMG_9128.jpg
    Sep 2007
    160
    Re: Help me identify this lead screw size
    Any one guys? any idea that can help me out?
    1943
    5/8-11
    Mar 2008
    683
    Plain ol' acme thread.
    Sep 2007
    160
    Quote Originally Posted by 109jb View Post
    5/8-11
    Is it 5/8-10 or 5/8-11? I thought it was 10?
    1943
    5/8-11 is common bolt size. Based on your pitch measurement of 2.3mm, that is 1/(2.3/25.4)=11.04 threads per inch. The common acme size would be 5/8-8. I assume you want a nut that actually fits. Neither 10 TPI or 8TPI is going to fit the screw unless your measurement is off.
    Sep 2007
    160
    It look like it should be 5/8-10
    10 thread per 1"
    Major Diameter .625
    Minor Diameter .498 to .533 (can't get a accurate measurement.
    But now I can't even find a simple freak nut that's 5/8-10 that cost less than 80.00. Some place has the nut for 25buck... but demand a minmum purchase of 60.00.. crazy,....
    Feb 2007
    4553
    Jimmyaz,
    A vendor on eBay sells cross feed nuts that you might be able to retrofit or maybe he might even make what you need.
    See attached link for details:
    derewa2 | eBay
    Jeff...
    Quote Originally Posted by jimmyaz View Post
    10 thread per 1"
    Major Diameter .625
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Lightbulb Re: Help me identify this lead screw size
    Or a ballscrew retrofit might be cost effective.
    Zyltech Antibacklash Ball Screw 1605 w ballnut BF BK12 End Support L 550mm | eBay
    Jeff...
    May 2008
    1185
    youtube videos of the G0704 under the name arizonavideo99
  1. Lead Screw pitch and Bearings,coupling for lead screw
    By Power_user_EX in forum Linear and Rotary Motion
    Last Post: 06-12-2012, 12:37 PM
  2. Can you please identify this type of lead screw?
    By rodjava in forum DIY CNC Router Table Machines
    Last Post: 03-29-2010, 04:12 PM
  3. hf 8x12 lead screw thread size
    By ubaldc in forum Uncategorised MetalWorking Machines
    Last Post: 02-15-2010, 09:40 PM
  4. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
  5. for engraving pcb which is a good thread size for the lead screw?
    By NickLatech in forum DIY CNC Router Table Machines
    Last Post: 01-18-2005, 03:37 AM
