586,121 active members*
3,135 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > EUROPE RFQ's > Rfq - aluminium 5083 preferred 300x300x25mm stock, one off.
    Apr 2014
    215
    Hello,
    Looking for a quote please for a flange in 5083 preferred. (All manner of file types attached below, pdf, ifc, solid works, and inventor, dxf....if you need something else, just ask)
    The only critical dimensions are the circular rebate and spigot in the centre which act as alignment dowels. The rest of the holes can be spotted and drilled. The outer profile can be rough finished.
    I would like a good finish on the flange faces (not nessesary on the top of the spigot or bottom of the rebate)... yes, I'm aware good is not specific but I'd expect that someone would understand what I mean by good as they are mating faces, and I'm more trying to explain the critical faces, than wasting machining time on those non critical bits (outer profile, top of spigot, bottom of rebate, and to a degree the bolt holes), this doesn't come across on a cad file very well.
    I'd like a reasonable turnaround please.
    I'm in the Northwest (uk!), Regular postcode L39.
    Pm me, thanks,
    Rob
    Feb 2014
    92
    Re: Rfq - aluminium 5083 preferred 300x300x25mm stock, one off.
    Hi Rob,
    We are interested to provide the quote. Can you let us know your email adrees, so that we can contact you for discussion? We can be contacted through this email address [email protected]
    BR
    /SL Wong
    Sales Manager
    Proto Tree LLC
    Website: Proto Tree
    Email: [email protected]
    Jul 2009
    85
    Pming you Rob
    I'm in US I would still like to quote your project.
    I am very late for this RFQ. But for similar needs, please send drawing at [email protected].
    We manufacture components for companies in UK, FRANCE and GERMANY,
  1. To use 6061 or 5083 aluminium for new build?
    By RomanLini in forum Benchtop Machines
    Last Post: 04-06-2020, 10:49 PM
  2. Preferred oil in one shot oiler?
    By bit pusher in forum Charter Oak Automation Support Forum
    Last Post: 10-31-2013, 06:22 PM
  3. Preferred Stepper
    By Rob K in forum DIY CNC Router Table Machines
    Last Post: 09-17-2011, 07:47 PM
  4. Aluminium round stock supplier in Dallas, Texas area.
    By ratslayer in forum Want To Buy...Need help!
    Last Post: 11-11-2010, 03:10 PM
  5. Preferred file for RFQ
    By turmite in forum Employment Opportunity
    Last Post: 01-25-2006, 12:37 AM
