586,077 active members*
3,688 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > SPINDLE OR ROTARY TOOL SPINDLE ON ALARM
Results 1 to 8 of 8
    Sep 2007
    122
    All,
    I am trying to Face Tap on a Mori Seiki CL-203B Machine. The machine goes in fine to the -0.625 point and then will not reverse the spindle and feed out.
    I get the EX0401 ( G1027) SPINDLE OR ROTARY TOOL SPINDLE ON ALARM.
    The section of the program is:
    T0808
    S150 M03
    G00 X0.0 Z0.5
    G84 Z-0.625 R-0.1 S150 F0.07692
    G00 G80 Z1.0
    Any light shed on this will be greatly appreciated. There is no good example of the G84 in the Mori Programming book. This alarm is also not listed.
    Hutch
    Sep 2007
    122
    Re: SPINDLE OR ROTARY TOOL SPINDLE ON ALARM
    This is a Mitsubishi Meldas Control.
    Aug 2016
    29
    Don't know about your Mori but on our Nakamura Tomes (Fanuc) we have to issue a M29 command first for rigid tapping. Looks like this:
    M29 S150
    G84 Z(depth) F(feed)
    G80
    Hope it helps.
    ~aj
    Sep 2007
    122
    Not_In_Use THanks, I will try that.
    I did write the code out long hand ;
    I CHANGED MY ZERO POSITION. The face that gets tapped starts at Z-0.500.
    G00 Z-0.25
    M03 S150
    G63 (Tapping)
    G01 Z-0.800 F0.0769
    M05
    G04 P0.1
    M04
    G01 Z-0.1 F0.0769
    M05
    G64
    M03
    This works which makes me think it has something to do with the machine reversing from M03 to M04.
    Sep 2007
    122
    I still have not found anything on this MSC-803 Mori/Mitsubishi control
    (flame2)
    Feb 2009
    6028
    FYI, no live tooling, no rigid tapping on that machine.
    Sent from my A3-A20FHD using Tapatalk
    Sep 2007
    122
    Is there a machine parameter that would cause this?
    FROM THE PARAMETER MANUAL
    12 SYNCHRONOUS TAP CYCLE ACCELERATION/DECELERATION TIME
    CONSTANT ERROR
    The time constant has not been set or the
    setting exceeded the setting range.
    • Check spindle parameters #3017 stapt1 to
    #3020 stapt4.
    Sep 2007
    122
    1171 taprov Tap return
    override
    Set the tap return override value for the synchronous
    tap.
    1 to 100 (%)
    1172 tapovr Tap return
    override
    Set the override value when leaving the tap end point
    in the synchronous tap cycle.
    The setting range is 1 to 999‚ and the unit is %.
    When a value less than 100 is set‚ it will be judged as
    100%.
  1. Replies: 4
    Last Post: 05-03-2019, 08:58 PM
  2. Hitatchi Seiki ht 30g 2213 spindle speed 0 alarm and 2246 cutting spindle alarm
    By nixwake2snow in forum CNC Machine Related Electronics
    Last Post: 05-07-2014, 05:24 PM
  3. Feeler FV-800 spindle and tool alarm
    By Ardo in forum DNC Problems and Solutions
    Last Post: 07-15-2013, 01:04 PM
  4. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  5. Spindle Tool Clamp/Unclamp Alarm
    By Q12321 in forum DNC Problems and Solutions
    Last Post: 10-10-2006, 09:24 PM
