586,560 active members*
4,066 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > HSMWorks 4th Axis Setup
    May 2013
    15
    Hi All,
    I'm feeling a bit stupid I cannot figure this one out. Google has not been my friend.
    I will soon be setting up a 4th axis rotary head/table (A-axis) on my mill for some parts I have coming up where I need to cut 7 slots around the perimeter along the axis of a tube.
    I'm using Solidworks Student Edition and HSMWorks Premium 2016. There must be a setting or configuration I am missing. In HSMWorks I don't see any drop down options for 4th axis. In my machine setup if I try to enable a rotary axis it does not take. Not sure what I am missing.
    Secondly, on the job setup how should the UCS be orientated if the axis of the tube is parallel to the X-axis?
    Other info:
    3-axis mill
    Mach3
    Jay
    Sep 2009
    1856
    Re: HSMWorks 4th Axis Setup
    UCS be orientated dead center
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
  1. Replies: 19
    Last Post: 06-07-2016, 05:54 AM
  2. Y-Axis / Z-Axis Bearing Setup Question
    By KittyPants in forum DIY CNC Router Table Machines
    Last Post: 08-22-2013, 10:45 AM
  3. Wanted: 4/5" pre-made Z axis for 3 axis setup
    By telmnstr in forum Want To Buy...Need help!
    Last Post: 05-14-2012, 09:52 PM
  4. Replies: 1
    Last Post: 07-26-2011, 11:28 AM
