Hi gang. I have a rectangle aluminum plate. .375 thick. 4 x 9. I want to run a 1/8 corner rounding operation on it. all the way around it. spec of CR end mill: 1/8 corner rad. 5/8 cutter OD. 1/2 shaft.
My question is how do I set that up in Dolphin CAM?
Attempted: In Dolphin I setup a contour around the part. .123 deep. in CAM I made a new endmill. For the endmill size I put .OD of .502 ( .625 - .123) and max depth .124.
In D-cam I setup the contour with left offset, use the .502 end mill, and Z of .123 in 1 pass.
Simulators are OK- But I really cannot tell if that will work as the sim cannot know that my .502 is really .625 and going over the edge by .123?
This is my first attempt at a CR end mill in a CAM/CNC setting. I'll need to play on a few scraps obviously, but I am sure there is some proper way that I simply do not know?
Thanks.
CG.
