586,104 active members*
3,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > code structures ...
Results 1 to 19 of 19
    Jun 2015
    4154
    code structures ...
    I have no experiece with CAMs, so i just program as i can
    i use parametric structures for simple operations as : rough turning, face milling, drilling, etc ...
    however, during testing i compared a simple program, with another filled with formulas ... every formula / calculation means a small delay, thus program will perform slower
    calculations are not complex, but easy ... what makes the machine to delay is the number of calculation
    so, even if there are "math functions", each one will slow down the machine
    is good to have a "read ahead" buffer, because things were worst without it, but even so, i did not expect such delays from the machine
    that "read ahead buffer" can not handle "math functions" in "real time" : in other words, the buffer is great for machining, not for formulas
    a simple program runs always almost the same, while another filled with formulas may run with ± some seconds
    i don't know yet how the machine behaves on G41/G42, or cycles, versus simple code .... kindly !
    Apr 2009
    1262
    Re: code structures ...
    Is there a question in there somewhere or are you just rambling!? Kindly!
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    question : G41 & cycles, or just code ?
    some structures are built in, so i guess they perform faster .... i did not test this yet
    Mar 2016
    25
    If in 2016 we still have to buffer towards a machine this is pure waste on time.
    What ever the G feature is, controllers are now supposed to read at speed they can access the data they can replicate within the axis.
    Jun 2015
    4154
    hy, this is not about buffering data from outside the machine, but about internal buffer ...
    this is general ... is the way the machine works
    Jul 2010
    287
    Not entirely certain there was a question in there still, but, Okuma machines by design pretty much read the entire program as it is selected, however, if I want things to happen based on other things, well now we get complicated.
    If you don't believe me, go to a Fanuc machine. Run a program without an M30 or M2 at the end of the program.
    Then go to an Okuma and try to load a program that doesn't have an M2/30. Or where you don't turn off G41/2 after you turn it on. The machine alarms before you can even load the program. "No end of code" alarm I believe.
    The machine is absolutely capable, most are really, the question becomes am I ready for the machine to read the code and do the math yet.
    For example, I often do things based on other machine conditions. IF[VORD[0001C] NE 0]NJUMP
    However, VORD[0001C] won't necessarily be 0 at the right time if the code is read too early in the program. Specifically if I'm checking for sub spindle clamp condition; I don't want the program to skip sub spindle machining when I first start the cycle before I've picked off using the sub spindle.
    In an Okuma lathe/OGL, M331 works for "buffer prohibit" and prevents the control from reading beyond that M code. Typically in the event I want to make a decision on what to do based on a variable external condition.
    On a mill, M331 doesn't do that and historically math would be done entirely too soon unless you filled the buffer with something. Typically people used G4 F.1 and repeated it 10 times or something like that number. Lots created G/M code macros of nothing but G4 F.1 to prevent read ahead issues.
    You can, in either case, use a statement that analyzes the current condition of something, such as VATOL in mill, which it won't read until that line, basically a mill version of M331 because the machine doesn't want to answer what something IS until it gets there, and I don't want it to do something based on what VATOL is 20 lines from now because there may be a tool change in there somewhere.
    Quote Originally Posted by Balistix View Post
    I would argue that in 2016 if we are still generalizing something as a "pure waste of time", we sure haven't learned much in the prior 2000+ years.
    I've spent hours staring at a part run which the operator described as a "pure waste of time" to me. (he actually said "complete f'n waste of time", but I digress)
    The next day I rearranged operations slightly and made 5/6 slight program changes without editing speeds/feeds that saved something like 30% of a 2 minute part that gets run roughly 100k of per year over 2 machines.
    In time savings alone that saved the cost of a new machine in a year.
    "waste of time"?
    Maybe from your perspective.
    Just not necessarily the only perspective.
    Jun 2015
    4154
    hy teahole
    If you don't believe me ...
    how could i ? )
    ... go to a Fanuc machine. Run a program without an M30 or M2 at the end of the program.Then go to an Okuma and try to load a program that doesn't have an M2/30. Or where you don't turn off G41/2 after you turn it on. The machine alarms before you can even load the program. "No end of code" alarm I believe.
    this behaviour on Okuma is a simple 'program check', that goes superficial ; "ahead buffer reading" goes deeper : for example, you may "program select" without any errors, but, during runing, something may show up
    if code is only coordinates, than machine goes fast
    if code is filled with formulas, machine goes slower
    for example, don't use G00 X = radius * sinus [ 30 * V1 ], but G00 X=56.895
    is better to do simple calculations outside the machine, and after, send the results to the cnc
    i think this delay is because the cnc does not behave like a computer, but is waiting for confirmation signals from the electronics
    For example, I often do things based on other ... on what VATOL is 20 lines from now because there may be a tool change in there somewhere.
    so far i have encountered a single case when "ahead buffer reading" made things harder for me : during driling, sometimes there were chips on the tool, but not always ... there was code with "/", so, if operator would push the "/" button, the drill/spindle would stop and raise 150...200mm, so easier to clean the tool
    because of the "buffer", pushing "/" would not act instantaneously, and this was not good
    i delayed the buffer using G00 Z = VWKBZ i know this variable from you, so thx again
    an alternative would have been to use peeking, so to cut just a bit each time > i did not like it, because machine would move more, thus unnecessary movements would appear ...
    Jun 2015
    4154
    I would argue that in 2016 if we are still generalizing something as a "pure waste of time", we sure ...
    30% of 2 minutes is nice especially if without messing with the cutting specs
    thinking economical is tricky, and even if something can perform better, this does not mean that it can not be left as it is ...
    there is a fashion to go improving at a low-level which has almost no impact on general mechanism
    generally is "time vs money" : faster means more expensive
    is important to determine quantificable parameters, and measure them corectly
    i asume that i have done something if at least 5% is gain ; some people consider 2.5% as a "change"
    this 2.5...5% tagets a phenomen / is important to know "how important is the phenomenon", because otherwise, it may be a "waste of time"
    Jul 2010
    287
    Quote Originally Posted by deadlykitten View Post
    That was the most drastic example i've got, it was not the rule of course, but it sure felt good.
    I have programmed machines with 5020 controls and used strictly macros, only AFTER getting a solid tool path program from the results of those maths. I have never seen an instance where the math in any way affected the speed with which even a 32 year old machine at this point, runs. Does that mean it isn't possible? nope. But i've not seen it.
    Jun 2015
    4154
    hello again tea hole
    yeah, i know that it was you who wrote that program, and also you corrected it
    [ mill ] i have a code that does cilinder roughing, as shown into attached image
    v1 ... only coordinates > 1:26
    v2 ... parametric structure, thus formulas everywhere > 1:30 ( "math overload" = 4 seconds )
    v3 ... v2 + extracting coordinates at every position > 2:00
    [ lathe ] i adapt same program :
    v1 ... 1.22
    v2 ... 1.23 ( "math overload" = 1 second )
    v3 ... 1.51 ( newer lathe ) / 1.57 ( older lathe )
    conclusions :
    ... lathes are faster, when it comes to math, at least mine
    ... simple coordinates are recomended, especially on mill
    ... "math overload" depends on formulas complexity :
    ...... simple formulas will trigger a smaller overload
    ...... "parametric structures" will trigger a greater overload
    ... coments and NOEX trigger delays as well : i heard that a lathe had a small delay when indexing, and it was because i had some comments before an operation; since then, i write all comments in another file, or i write them after M02 without brackets
    ... coordinates extraction comes with greater delay, because of each "file open - file write - file close" , but this is less important, because such techniques are used to generate the main code, and should not be left active
    Jun 2015
    4154
    coordinates/data extraction delay duration may be reduced by using a single CLOSE , at program's end, and not for each position; this is for my program :
    .... CLOSE @ each position : total time = base duration + delay
    .... CLOSE @ program end : total time = base duration + delay * 0.33
    on the other side, a single CLOSE does not allow multiple file writing
    Jun 2015
    4154
    Hello, these questions are a bit weird in this post is the 1st one :
    simple code is performed faster
    some things will slow it down, like conditional code ( if, jumps ) and a lot of arithmetics ( especially in parametric structures, for example like this structure for splines that is mrore versatile than a cycle : http://www.cnczone.com/forums/okuma/309768-cnc.html )
    what i don't have tested yet is " simple code " vs " default cycles "
    well, that being said, i have procedures that are filled with conditional code ( if, jumps ), and they make things easier, so is ok to have them, and i don't like that the cnc loses time when is computing them, because it does a lot of background checkings; so : is it possible to reduce the ammount of background checkings performed by the cnc, at least ( only for ) some codes ?
    Code:
    M/G... ( disable / lower background checkings level )
    some code
    M/G... ( default background checkings level )
    how to implement those M/G codes ? kindly !
    Jun 2015
    4154
    now the 2nd one : let's consider a program that is in the MD1.
    each time when the program is restarted at a specific position, the machine goes in background over it until it reaches that specific position.
    if the program is long, than this procedure will take some time; and if the restart is repetead, than it will take some amount of time as before ...
    is like the machine compiles that code each time, even if the code has not been modified
    is there a posibility, or did someone think of eliminating this behaviour ? so to compute a code as new only one time, and after that to load it faster if nothing changed ? well, off course, as long as the program is <2mb, or it's size is under the buffer required for one time shot, so program size is small enough to be loaded entirely ...
    code for a new program should be compiled once into an aplication that remains in the volatile memory; next time the cnc should not run the program, but that aplication
    in my opinion, this is not impossible, but i think that the cnc developers don't take it into consideration, because it's result does not affect the speed for computing a program, since loading stuff each time in the virtual memory is pretty fast, and if the code is long, even it is simple, is not their problem. If read ahead buffer is there, than they consider this more than enough
    if this would be done, than the gain will be seen on reduced ( almost instant ) duration when restarting, even in long programs ; during compiling, maybe it will buff a bit the read ahed buffer also, this will reduce / optimize data flows through those eletronics
    Feb 2005
    303
    There are many reasons for Okuma re-loading the program under certain circumstances. One reason is the use of .ssb routines. If a subprogram has been edited, there is really no way for the control to realize that. Likewise, if the main or sub programs rely on variables as many programs do, then re loading the program ensures the currently-stored values will function correctly. If the machine has been moved, or if the program uses counters or modifies variables as each tool runs, the the program MUST "compile" the program to make certain all calculations are accounted for before just blindly starting the program from the middle. There are other examples, but I believe you see my point - there are many features on a CNC that a person may not use, but the machine behaviour is built around ensuring all features function safely and correctly, even if you do not use all of those features. Eliminating this behaviour may make your life easier, but people who use their machines for more complex jobs, family-of-part jobs, or even something as simple as custom subprograms, will suffer greatly as a result.
    Deep-hole drilling with the Okuma peck-drilling G codes goes much slower than if the moves were written in a variable-controlled loop, but using no variables in a program with a lot of drilling will only make a longhand deep-hole drilling cycle take longer, as the program will consume far more memory to run. The canned cycles in the control are generic, and spend a lot of time behind the scenes taking care of a lot of heavy lifting that you may not need, or even be aware of. Replacing these cycles with a variable-driven subprogram that only perform axis moves can save 2-3% of the cycle time, depending on the number of holes in the program. It is all a matter of what you intend to accomplish with your program.
    I do not understand that statement. Cutter comp is, and has been for decades, a simple code. What, exactly, is your concern with using it?
    Please do not give out advice like this. Once again, just because something is better for you, in this particular instance, does not mean you should post that it is better for everyone. One of my machines is picking part numbers to run on the fly based on the available material. Drill point tip height, RPM, and feedrate are calculated when a drill is called up (The machine has 7 drill diameters to choose from, and only calls up the drill that will work to make the hole size required), and my drill cycle handles drilling every hole with one subprogram that is less than 15 lines long. Every tool rapids to a calculated position based on material size before and after the cycle. Cutting conditions are calculated based on the tool and the material. And so on. The reduction in program storage, not to mention the time to locate and manage and keep track of the 200+ programs it would take to achieve this by not using calculations or custom subprograms saves literally hours a day.
    Jun 2015
    4154
    There are many reasons ... will suffer greatly as a result.
    hy ghyman, yup, there are lot of variables, but i think those variables may be classified, and each class should be taken a propper approach.
    is not impossible, but it requires some work that i don't think that Okuma guys find it relevant
    it would be easier if the osp was an operating system based software, but is not; it is a bit on his own, and all comunications with the operating system are made to some whatever interfaces that is opened partially to a programer through the API; it's core is not on the hdd, there is just the build from Okuma which is a bit hard to get into by normal guys
    if it was based on an operating system, than it's language would be common, and a lot of remote programmers could works on that, but since it is encapsulated, only "some" guys can do the work, so their resources are limited on this.
    about comp, i don't know if is faster to :
    ... 1) use the part dimensions as the toolpath + G41/2 + radius declaration + P declaration , or
    ... 2) use a virtual toolpath, thus no G41/2, no radius declaration, no P
    what i know is that the comp (1) comes with unnecesary movements, at toolpath "start" and at "end"; so far i managed to solve this easy for the "start" position, by using imaginary vectors, while for end is a bit different
    so i guess / hope that (2) is faster than (1), so i won't mess my head with this unnecesary movements any more
    i will reload let's compare how a lathe igf generates code for a roughing operation, vs how a mill igf generates code for a helix
    lathe igf will output the shape between some master codes, that will tell the cnc to do some background calculations for the toolpath; thus code is simple, while toolpath is complex, for each pass, being computed "inside"
    mill igf will do some math, and will output the code for the toolpath, so there will be less background calculations
    in this case, the mill igf does some calculations in advance, so to spare the control
    so outside calculations, or if you wish, calculations done before generating the code should reduce "background" calculations done by the cnc when code is executed
    One of my machines ... saves literally hours a day
    this is parametric code; parametric code is another story
    well, not another story, like there is no connection between them; when i said that "is better to do simple calculations outside the machine, and after, send the results to the cnc", i was not refering to parametric code
    also, parametric code optimizations is an issue, because if you fill it with conditions and stuff, than it will work slow
    parametric code is much close to programing than a simple cnc program, but yet, if you optimize a parametric code to shorten it, than the cnc will perform it slower, because is not build for conditional programing this is why in a previous post i asked if is it possible to reduce the ammount of background checkings performed by the cnc, at least ( only for ) some codes ?
    Jun 2015
    4154
    by the way, how do you compute feeds ?
    what do you think about a constant specific for each material type ? it may boost that code of yours
    Jun 2015
    4154
    pls check attached image
    feed for soft metal : f = 0.017*dia + 0.075, or 0.05 * dia ^ 0.7
    1st one is easier to implement in a *.ssb
    fine adjustment by corection factors : 80%f .. 120%f
    multiplicators for plastics, for example : f x 1.5 ... 4
    ps : rpm = V * 1000 / VPAI / diameter > V*320/dia or V*318.30988618/dia ( depends how tolerant you are )
    well, i guess you know al these things; all the best
    Jun 2015
    4154
    hy all there is the posibility to reduce code's length by :
    ... removing comments + useless blanks/spaces
    ... concatenate lines
    attached image shows an example
    idea behind this thread is to reduce resources required to run a program : in this case a tiny bit of time gain + less file size
    Jun 2015
    4154
    Quote Originally Posted by ghyman View Post
    hy ghyman yup, i know, it has been almost an year
    i am afraid that it was not about a particular case : osp300 looses precious time when performing simple calculations; using NOEX will fix that
    this behaviour should be present also on some elder control generations / kindly
  1. Replies: 51
    Last Post: 09-16-2020, 01:28 AM
  2. Replies: 0
    Last Post: 11-24-2014, 12:42 PM
  3. corel.hpgl > sheetcam.tap > pronterface.g-code > slic3r.g.code> ramps 1.4 > H-BOT
    By thesignworks in forum Uncategorised CAM Discussion
    Last Post: 05-25-2014, 02:11 PM
  4. Reinforced concrete damping for steel machine structures.
    By JohnMcNamara in forum Epoxy Granite
    Last Post: 04-24-2011, 08:02 PM
  5. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
