586,060 active members*
4,182 visitors online*
Thread: CS Trouble
    Sep 2016
    CS Trouble
    We have a job that consists of 5 completely different parts, that will be sold as a set, with several sets to make. I would like to machine the 5 parts all on the same tombstone, with a different CS for each one. I can get the code to output G55, G56, etc., but what I cant seem to figure out is why the X&Y absolute values are still based off CS1. I would like each CS to be zero at its respective location.
    Sep 2007
    133
    Re: CS Trouble
    its possible post your file and someone will have a look at your current machine that you use.
    also depends on the post output if it allowes it or not..
    Sep 2016
    Re: CS Trouble
    Ok, I will attempt to attach a .vnc file of a sample program that should illustrate the problem I am having.
    If anyone can point out what I am doing wrong, I would greatly appreciate it.
    Attached Files Attached Files
    May 2012
    83
    Re: CS Trouble
    I posted with my post and it gives g54 xy 0 and g55 xy 0...you probably do not have correct post
  1. Trouble cutting circles. Trouble with y-axis
    By chrisv7 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-08-2016, 09:43 PM
  2. New to this... having trouble.
    By dan3676 in forum PhotoVCarve and VCarve Pro
    Last Post: 07-04-2014, 07:25 PM
  3. TL 1 trouble
    By WOB729 in forum Haas Lathes
    Last Post: 05-07-2008, 01:27 PM
  4. THC trouble?
    By Red Earth in forum DynaCNC
    Last Post: 07-01-2007, 03:04 PM
  5. More PIC trouble
    By robe_uk in forum CNC Machine Related Electronics
    Last Post: 10-10-2006, 09:13 PM
