586,780 active members*
7,463 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Alarm 1001 during probing, VM-2
Results 1 to 8 of 8
    Oct 2010
    30
    At the end of probe calibration I get alarm 1001. Program works OK, but at the end, instead message PROGRAM END, I can see RUNNING, and then alarm 1001. May be problem with macros? How to fix it?
    Oct 2010
    30
    Re: Alarm 1001 during probing, VM-2
    Quote Originally Posted by Andriy77 View Post
    Alarm OTS swith off failure
    Feb 2010
    1184
    Try reloading all of the macro programs for your probe. Most of the times when the probing routines are having strange errors, reloading the probing macro programs fixes the issues.
    Oct 2010
    30
    Quote Originally Posted by haastec View Post
    I tried to reload few versions of macro programs, but it doesn't help. Periodically appears alarm PROBE OPEN, when start probing.
    Feb 2010
    1184
    First the problem was at the end of the cycle, now it is at the beginning.........
    Just to be clear, we are talking about the OTS (wireless table mounted tool setter) correct?
    If the batteries are weak or if you have any obstructions to the line of sight IR signal, such as a coolant line, both can cause your PROBE OPEN alarm.
    Feb 2010
    1184
    Did you try reloading specific individual macro programs or did you erase all macro programs for the probe and reload?
    Oct 2010
    30
    Thanks all for help,
    I have TS27R, but I loaded mistakenly program for wireless probe. I changed program, and now probe works correct. Wired probe always "open", wireless are closed after probing.
    Feb 2010
    1184
    Glad you got things sorted out! :cheers:
  1. Alarm message 1001 21i T
    By Bill Gillen in forum Fanuc
    Last Post: 11-28-2023, 11:33 AM
  2. Hardinge VMC 1000 alarm 1001
    By WTF in forum Bridgeport / Hardinge Mills
    Last Post: 09-16-2015, 06:15 PM
  3. Replies: 5
    Last Post: 03-18-2015, 09:37 AM
  4. 1001 Questions
    By MetalShavings in forum SprutCAM
    Last Post: 10-09-2011, 11:20 PM
  5. 1001 lub timeover
    By Reyad in forum Fanuc
    Last Post: 04-20-2011, 08:57 PM
