586,060 active members*
4,154 visitors online*
    Mar 2006
    24
    3D toolpath help
    Would you guys look at this file and see where I'm messing up? :-)
    When I post the code, my deepest -Z cut is only .1875", and it should be at -.25. I can't seem to figure out what I'm doing wrong. If I use the translate function and move the top face of my part to -.0625 below Z, then my -Z is correct at -.25 for the deepest cut. Weird.
    Attached Files Attached Files
    Mar 2006
    24
    Here's the cad file that goes with it..
    Jul 2006
    117
    Dfennell, I loaded the DXF into bobCad. The top surface is at Z = 0.0619. The bottom surface is at Z = 0.1875. Move the whole object down 0.062 and then the top will be at 0 and the bottom at 0.250
    Gene
  1. Toolpath question
    By COPO427 in forum Mastercam
    Last Post: 11-15-2006, 05:37 PM
  2. How do you create this toolpath?
    By squarewave in forum Mastercam
    Last Post: 10-18-2006, 01:40 AM
  3. Picstep 4 Toolpath
    By elogicca in forum CNC Machine Related Electronics
    Last Post: 07-22-2006, 04:24 AM
  4. Project Toolpath on STL
    By Sanghera in forum Mastercam
    Last Post: 03-13-2006, 01:43 AM
  5. Help with producing a 3D toolpath
    By ngr1 in forum Mastercam
    Last Post: 12-27-2005, 04:31 AM
