586,036 active members*
3,654 visitors online*
Thread: Raised text.
    Apr 2015
    8
    Raised text.
    I'm working on a project that will require a 5mm font
    raised by 1mm of which I will be making a latex mould. I will be using a 1mm ball nose cutter.
    Can foamex board be used for this type of milling. If not any suggestions on type of material to get clean sharp text?.
    Mar 2011
    59
    Re: Raised text.
    Hello,
    Although I personally have not had the chance to use these FREEMAN products myself, I have heard good reviews: https://www.freemansupply.com/produc...styling-boards
    Hope this helps.
  1. Replies: 1
    Last Post: 06-22-2014, 04:49 AM
  2. Replies: 8
    Last Post: 07-26-2013, 01:24 AM
  3. Text that is both raised and V-cut
    By bsimages in forum Vectric
    Last Post: 12-25-2011, 06:17 AM
  4. Raised Text
    By roland88 in forum Uncategorised CAM Discussion
    Last Post: 11-19-2007, 10:35 AM
  5. raised letters
    By zcases in forum OneCNC
    Last Post: 01-13-2007, 06:53 PM
