586,036 active members*
3,743 visitors online*
IndustryArena Forum > CAM Software > CamBam > A new Module to engrave with 4 passes
    Jul 2016
    Hello guys,
    I just wrote a module for CAMBAM. It will transform your use of the V-Engrave module.
    It manages V-Engrave leaks, large surfaces for huge engraving by calculating 3 roughing passes.
    Engraving made industrial.
    Never more hours of CAO to correct ungravable patterns.
    Give it a try...
    It is in French for now, but so simplistic to use.. I finish the english version of the doc soon, i promise.
    Module de gravure pour CamBam - Briosoft
    Jul 2016
    Re: A new Module to engrave with 4 passes
    Hello again,
    The documentation in english has been added.
    You may download the zip containing the plugin and the docs at :
    http://www.briosoft.com/BrioGrav.zip
    Enjoy...
    Sebastien
  1. Finishing Passes
    By laserpilot in forum Vectric
    Last Post: 07-29-2012, 02:13 AM
  2. How to do finishing passes???
    By Smooth90 in forum CamBam
    Last Post: 05-06-2011, 04:10 PM
  3. G76 Number of Passes
    By eliot15 in forum G-Code Programing
    Last Post: 04-09-2011, 12:51 AM
  4. finishing passes of G76
    By sinha_nsit in forum Fanuc
    Last Post: 12-23-2010, 08:23 PM
  5. Roughing Passes Exceeding Finishing Passes
    By phoodieman in forum Mastercam
    Last Post: 03-01-2009, 01:21 PM
