586,112 active members*
2,999 visitors online*
Page 2 of 2 12
Results 21 to 39 of 39
  1. #21
    Oct 2006
    51
    a bit off topic, but you don't really need helical interpolation to mill an npt thread. just cut the thread into 4 90 degree arcs and adjust the radius for the taper.
    like this
    G01Z0F30.
    G01G41X-.301D28F5.
    G03X0Y-.3014R.3014Z.0139F10.
    G03X.3017Y0R.3017Z.0278
    G03X0Y.302R.302Z.0416
    G03X-.3024Y0R.3024Z.0555
    G01G40X0F15.
  2. #22
    Feb 2006
    1792
    Quote Originally Posted by HIRAH View Post
    like this
    G01Z0F30.
    G01G41X-.301D28F5.
    G01G40X0F15.
    I am a bit confused. I understand that G02/03 with a Z word is helical interpolation, as written in the 0i MB manual. So, you are using helical interpolation only. Or, is there a separate G code for helical interpolation? Incidently, your method will change the radius in steps, at every quarter circle. So, the helix will not be smooth. Possibly, the helical interpolation people are talking about, changes the radius smoothly. But, it does not seem to be available on 0i series controls. Pl clarify.
    S.K.Sinha
  3. #23
    Jul 2008
    15
    Hi!
    I would need a parameter to turn on helical interpolation on Matsuura MAM-600HG machine with Yasnac i80M controller which I think is based on Fanuc controller, just not sure which one. Any help on this would be appreciated!
    Thanks!
  4. #24
    Feb 2006
    1792
    Somebody might let you know, though it is illegal. (I do not have)
    Incidently, when one looks at some of one's old post, it appears so foolish!
    But, this is the way one learns. Never hesitate in asking. I still ask too many questions.
  5. #25
    Mar 2005
    816
    I just tried that program tonight on my 18iMA. It works.
    I don't remember if I have the Macro A or B. But I tried this in manual guide too.
    What would make the interpolation smoother?
    That's what I understood about G02 & G03 but I noticed that there was also a G40 and G41 there too. Not that I know much about helical moves.. except for more trichoidal moves. Sinha, I didn't see any other G code for helical.. at least that would work for a threading operation.. not that I ever milled or turned NPT threads.
    This program had X near .301/.302 with the same R values.. while Z changed with the feedrate which seemed to go a bit faster from F5 to F15. Theres a sneaky D word in there too.
    Thanks for the 16M paramater, Al. I put that one in the param list for my 16M when it gets finished..
    Greg
  6. #26
    Feb 2006
    helical interpolation on seiki seicos 10 control
    Please help! I need the parameter to turn on helical interpolation on seiki seicos 10 control. We have a Hitachi Seiki vm-50 and it lost information when we changed a battery. I thought we backed everything up correctly, but now it wont do a helix.
  7. #27
    Sep 2012
    182
    stupid question how do you change the parameter?
    I can change other parameters ie I tried changing 0038 it and it worked but 0910 wont change. I get the alarm that it needs to be powered off, but it never accepts the parameter change and it stays the way it was.
  8. #28
    Aug 2011
    2517
    the procedure to change option parameter for 0M is different to that shown above
  9. #29
    Sep 2012
    182
    I played around some more and found I could change some 900 parameters and not others.
    I found the 3 axis control at once, and thought that might allow for helical interpolation but I still cant set 910#3.
    possibly I can't set it as 0m-a mate controls can't do helical interpolation?
  10. #30
    Dec 2008
    239
    Back up your data param first, reload by DNC it will change
    Regards
  11. #31
    Sep 2012
    182
    Quote Originally Posted by yours_prabhat View Post
    Regards
    do I need to wipe the parameters first via reset+del on startup before reloading?
    I don't think I'm brave enough to do that.
    everything that I have read indicates 900 series parameters must be first input by hand.
  12. #32
    Aug 2011
    2517
    follow the correct procedure.....
    Fanuc 0 Memory Backup Procedure
  13. #33
    24221
    Quote Originally Posted by landslide1 View Post
    Just the RS232 parameters in order to load by serial port.
    Al.
    Attached Files Attached Files
    Albert E.
  14. #34
    Sep 2012
    182
    Quote Originally Posted by fordav11 View Post
    that if for a system restore and indicates you should wipe the parameters and memory.
    Step 2: Initialized/clear memory by press and holding "RESET" & "DELETE" keys simultaneously while powering ON the control.
    also in step 4 it says to input the 900's manually.
    Al.
    the bit about "reading CNC parameters (PC->CNC) looks like you don't need to clear the parameters first.
    I have a txt file of my parameters that looks like below. it has line breaks at the 700 to 900 parameter jump and between the 900 and 1000 parameters. and another between the 8000's and 9000's. can I just read this in over my current parameters?
    N0001 P 01011000
    N0002 P 11100011
    N0003 P 01000001
    N0004 P 01111001
    N0005 P 01111001
    N0006 P 01110111
  15. #35
    Aug 2011
    2517
    I didn't say blindly follow those instructions.
    The procedure says 'If control is generating System Errors.....'
    Your control is not generating errors so you skip that part.
    I said (or implied) READ IT then you will know more about what to do. The answer (to change just one parameter) is in the text but you must read the procedure to know the method. Then you skip the 'wipe' part and just enter the parameter(s) manually. Basically enable PWE and follow step 4.
    If that doesn't work backup your parameters and follow the restore procedure, enter your options etc.
    When outputting parameters press EOB and OUTPUT START together to send the 900 (option) parameters so you have a backup of them. This does not work when inputting parameters however. 900's have to be restored by manual entry.
    I've attached another procedure, this one is basically the same thing but in a pdf and a more official type of doc provided by GEFanuc
  16. #36
    Sep 2012
    182
    a warning to any other newbies out there.
    I tried loading parameters in over the old ones. it lost the Zero return position. it hasn't happened every time I have tried, just the first.
    make sure you know how to re-zero you axis before you try silly stuff!
  17. #37
    Quote Originally Posted by Dan Fritz View Post
    It's 9100, bit #2 (the 3rd bit from the right)
    Can u tell me the optional para for helical interpolation for 31i B control please.
  18. #38
    24221
    Re: helical interpolation parameter
    Quote Originally Posted by Masoudrezaie View Post
    Dan hasn't been seen since 2007 !!
    Albert E.
  19. #39
    Aug 2019
    145
    If I'm not mistaking the 31i-B will require purchasing the option as it is done through a file updated by Fanuc. And Fanuc has been touchy on options lately and may require you to go through the OEM or distributer.
Page 2 of 2 12
  1. helical interpolation 15m
    By Goran P. in forum Fanuc
    Last Post: 01-21-2020, 10:05 AM
  2. Helical Interpolation in V14.2 Pro
    By squarewave in forum CamSoft Products
    Last Post: 07-27-2013, 04:11 AM
  3. parameter for helical interpolation on seicos 10 control!
    By HAMSLAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2012, 07:16 PM
  4. Helical Interpolation
    By jjproto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-10-2011, 10:59 PM
  5. helical interpolation parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2007, 12:10 AM
