586,117 active members*
3,329 visitors online*
Page 1 of 2 12
Results 1 to 20 of 39
    Mar 2005
    110
    helical interpolation parameter
    We have a couple Mori Seiki MH-40 horizontals. On the one we can do helical interpolation ie pipe threads and on the other we can't. So I believe we need to turn on one of the 9100 series parameters. Can someone tell me which one it is? Thanks! Oh...it's an 11M control/
    Sep 2005
    767
    It's 9100, bit #2 (the 3rd bit from the right)
    Mar 2005
    110
    Thanks Dan
    I turned it on today with no difficulty.
    BTW we've been using your software for more years that I can remember. It's the best!
    Jan 2006
    4396
    Quote Originally Posted by Dan Fritz View Post
    Sorry for the interuption guys (wrong)
    Nice DNC Software Dan. I'm very impressed.
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Can u tell me the optional para for helical interpolation for 31i B control please.
    Dec 2003
    24221
    Re: helical interpolation parameter
    Quote Originally Posted by Masoudrezaie View Post
    Dan hasn't been seen since 2007 !!
    Albert E.
    Sep 2005
    767
    Gosh, thanks guys. Nice to know someone appreciates all those late nights at the computer.
    Dan
    Jan 2006
    4396
    Dan
    Looks like you spent a lot of time writing that. If I ever need a new DNC Software, yours is the first on the list :rainfro:
    Toby D.
    Schwarzwald
    Feb 2007
    3
    Mr. Fritz,
    I have an Fanuc 11M also, and just today was made aware that this machine is incapable of helical arcs. Unfortunately parameter list does not show #9100, I believe it might be hidden. Would you please explain a method to make visible.
    Thanks,
    Dan #2
    Sep 2005
    767
    TheePress: The parameters in the 9100 area should be visible on all Fanuc 10, 11, 12, and 15 controls. They are not hidden. Be sure to press the SYSTEM soft-key (not the SETTINGS soft-key). Under SYSTEM, you should be able to see all the parameters. Under SETTINGS, you will only be able to see certain selected parameters that don't need to be un-locked with the PWE bit.
    You should be able to see these parameters in binary, but you can not enter the option paramters like the other parameters. You must use the special procedure that has been described before on this forum. Just to recap, it goes like this:
    power off, press "-" and "." at the same time, turn the power on, enter "99" then INPUT at the ILD menu, enter the number of axes, then enter each parameter in the 9100 range in hexadecimal
    Good luck.
    Dan
    Feb 2007
    3
    :rainfro:
    THank You...Mr. Fritz,
    Succesfully added helical option, following youre procedure.
    In the future, could i not download parameters as a text file to computer, then use editor to change values in binary format and reload to machine?
    What other goodies might be enabled under these option parameters?
    Sep 2006
    12
    Good luck.
    Dan
    It is realy grt.
    Can u tell me the optional para for helical interpolation for 16 M control please.
    Feb 2007
    hey there,
    does anyone have option parameter for fanuc 0?
    thanks
    Sep 2005
    767
    Try parameter 910, bit #3 (the 4th bit from the right)
    Dec 2003
    24221
    9930 bit #3
    Al
    Albert E.
    Sep 2006
    12
    9930 bit #3
    Al
    Dear AI_The_Man ---- Thanks a lot my friend. It is working.
    Sep 2006
    12
    Helo .....
    In Fanuc 0 Model B - I want to know the custom macro External output commands (DPRNT, BPRNT, POPEN, PCLOS) are there or not. In our machine custom macro (G65P..) is working but when it executes POPEN or any other external output commands it gives an alarm 113 (Improper command). To enable this any parameter is required?
    Pl help
    May 2007
    42
    Dear Mr. Shantha,
    It's 9930, bit #3 (the 4th bit from the right)
    Good luck.
    Sung
    Sep 2006
    12
    Quote Originally Posted by Sung daecheol View Post
    Dear Mr. Shantha,
    Good luck.
    Sung
    Thank you verymuch. It is working.
    Pl help
    Sep 2012
    182
    I played around some more and found I could change some 900 parameters and not others.
    I found the 3 axis control at once, and thought that might allow for helical interpolation but I still cant set 910#3.
    possibly I can't set it as 0m-a mate controls can't do helical interpolation?
Page 1 of 2 12
  1. helical interpolation 15m
    By Goran P. in forum Fanuc
    Last Post: 01-21-2020, 10:05 AM
  2. Helical Interpolation in V14.2 Pro
    By squarewave in forum CamSoft Products
    Last Post: 07-27-2013, 04:11 AM
  3. parameter for helical interpolation on seicos 10 control!
    By HAMSLAM in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2012, 07:16 PM
  4. Helical Interpolation
    By jjproto in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-10-2011, 10:59 PM
  5. helical interpolation parameter
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2007, 12:10 AM
