586,094 active members*
3,904 visitors online*
Results 1 to 13 of 13
    May 2010
    222
    Broke 1/4" straight routerbit
    Ok i was cutting piece maple ply feed rate was 30 ipm 24000 rpm 1/8" depth of cut broke after cutting approximately 20" was steel body carbide tipped bit!
    any thoughts as this should not have been strain on this bit!
    May 2005
    3920
    Re: Broke 1/4" straight routerbit
    Possibly the bit wasn't ground right for the feed rate.
    I'd look closely at the bit to see if material had accumulated in the flights. If a bit plugs up it will snap pretty quickly.
    A manufacturing defect is always possible. You would need to look closely at the break to see if this is a factor.
    A sudden acceleration from a stepper or servo based system could snap a bit. This could come from noise in the system or something else.
    May 2010
    222
    it was brand new bit was clean as said cutting at slow rate of feed and only 1/8" deep and just fell apart like it was cheap Chinese piece junk lol!
    feed rate 30 ipm is slow like snail
    May 2005
    3920
    Quote Originally Posted by R L Harris View Post
    Maybe it was!
    If there was something wrong feed rate wouldn't matter much. Post some pictures, there are a few guys with experience with metal failures on here that might help. This include pictures of the cut.
    Going too slow can generate a lot of heat and cause failure.
    Where did the bit break? At the collet? Or somewhere else?
    1 flute or 2?
    I've always found small carbide tipped bits to be rather fragile.
    May 2010
    222
    This is the end of cut where bit broke the cut was 1/8" deep in 3/4" maple ply feed 30 ipm bit rpm 24000
    and the bit pieces with break points showing
    the bit pieces were not hot as picked it up with bare hand it just sheard floped over like it was weak at break point
    May 2010
    222
    I am going to get solid carbide bit and drop rpm 18000 and increase the feed to 40ipm
    Apr 2004
    5737
    What kind of machine are you using? What sort of spindle? For a dedicated wood router, 30 ipm (or even 40) is really slow. Most wood-cutting toolpaths run about 10 times that fast.
    Andrew Werby
    Website
    May 2010
    222
    I am bumping up speed to 100 ipm i would go higher if it had long cuts but this is only 12" x 12" part with bunch turns in it!
    What brand bit was that?
    At 40 ipm, you should drop the rpm to 10,000.
    I usually cut at 125-150ipm and 12,000 rpm.
    At work, we cut at 450ipm with 1/4" solid carbide bits at 18,000 rpm.
    Nov 2010
    520
    Does this bit have a cutting edge all across the bottom?
    Most of my work is small, so I keep the IPM down to the 30 IPM range, the speed in the 10K range and I ramp down to the cutting depth. I also use a solid spiral up-feed bit. I know carbide is brittle, but I have never broken a bit, as he knocks on some wood.
    May 2010
    222
    Ok bought upcut spiral as i can radius the edge little all went well rpm was 18000 feed 100 ipm
    Attachment 332802
    Feb 2005
    829
    I have been using Amana and Onsrud bits in my CNCRouterparts machine. I have been feeding a 1/4 compression bit at upto .375 Depth of Cut, at 160-200IPM at 24,000RPM and have been really really happy with the surface finish of the cuts. I Have been surfacing the table at 400IPM with a 2in Magnate Surfacing bit at .025 DOC no problems also.
  1. DIY 96" sheet metal bender- Pan/Box, Straight Just for .063" aluminum
    By diyengineer in forum Bending, Forging, Extrusion...
    Last Post: 11-25-2011, 04:37 AM
  2. Not cutting "straight?"
    By Tram in forum CNC Wire Foam Cutter Machines
    Last Post: 07-23-2010, 05:26 AM
  3. Just broke *TWO* 1/16" end mills...
    By geneb in forum MetalWork Discussion
    Last Post: 05-31-2009, 03:57 AM
