586,072 active members*
4,739 visitors online*
Thread: Axis inhibit
    Mar 2010
    10
    Axis inhibit
    Hi according to my manual when performing a dry run the xy & z axis should not move except for tool change. Mine however runs everything in rapid. Any ideas on how to stop this. Arrow 1000 with A2100 control.
    Cheers
    Dec 2006
    584
    Re: Axis inhibit
    What machine and what control do you have???? Dry run does make everything run in rapid, that is what it is for.
    Mike CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
    Sep 2009
    45
    Re: Axis inhibit
    It kill the cutting fluid pump on our Arrow 1000/A2100 as well. Found that out the hard way, some dummy pushed the button on the pendent by accident then told me the pump was broke. Wasted two hours trying to figure out why the pump safety relay wouldn't pull in. I don't drive 'em, I just fix 'em.
    Mar 2010
    10
    Re: Axis inhibit
    Hi mike it's an arrow 1000 A2100 control. As stated the manual says it should run in x& y only perhaps the manual is wrong. Other machines I have worked with also run through the program with no axis movement at high speed for error checking which is handy.
    Dec 2006
    584
    Re: Axis inhibit
    I think on the pendent you should have an axis inhibit using the soft keys and more. It might be under setup.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Z-axis Inhibit (dry run?)
    By Mooser in forum Tormach PathPilot™
    Last Post: 03-20-2016, 08:51 PM
  2. AMC 100A40 braking circuit and inhibit.
    By G59 in forum Spindles / VFD
    Last Post: 08-25-2014, 01:07 AM
  3. SL35 Spindle Inhibit in Jog
    By dmh007 in forum Mori Seiki lathes
    Last Post: 08-26-2010, 11:22 PM
  4. Inhibit spindle alarm
    By bigbobr in forum Fadal
    Last Post: 02-15-2008, 06:38 PM
  5. Inhibit vs phase chopping
    By stragenmitsuko in forum Open Source Controller Boards
    Last Post: 02-02-2008, 06:18 PM
