586,103 active members*
3,460 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > -X toolpath generation for GT27 lathe
    May 2012
    41
    Hi all,
    Newbie to Fusion 360, trying to warm up to it. The below might be a show-stopper.
    My GT27 lathe, with gang plate, Fagor 8037 controller, has tools on both sides of the gang plate, hence, depending on which tool I use and where it comes from, I need tool paths generated in both +X and -X direction. I have done some basic research here, and I am getting the impression Fusion can't handle the -X direction as all paths are from +X, no matter how your tool is setup in the library. So, I saw one post calling this a simulation issue, but is bigger than this. Basically, I can't generate G code. If I do generate it, I am left with manually adding a "-" sign in all the X moves that need it....ripe for mistakes and crashes.
    Can anyone confirm and is there a work-around? I suppose a custom post could be created somehow to say "if you are using tool #3, make all the X values -X values" or something like this. Seems clumsy, but maybe will work. Anyone want to try making a post like this?
    Paul
    Paul - milling since March 2012 - Solidworks/HSMExpress/Tormach1100 user
    Re: -X toolpath generation for GT27 lathe
    Hopefully you've been able to resolve this issue by now. If not, I would recommend that perhaps you try using something like the "Turret" value in the tool library to specify front or back tools?
    That would make it easy for the post processor to check and apply a negative conversion factor for the tools you specify.
    Dave
    May 2012
    41
    Hi Dave,
    Thanks for the comment. Yes, I think that is exactly what will need to be done; maybe assign a "1" to left side tools and "2" to right side tools.
    I thought I'd post a response so others can take advantage of my work-around, which is somewhat less painful than what I initially thought. What I am doing is manually programming a "mirror X" G-code right before the tool number. If it is coming from the -X direction, in my case, it is G11 (and G10 cancels). So with this quick addition, I do not need to go through and add a "-"sign. Works slick, but still not ideal of course, as it is not incorporated in my post and something I need to do manually each time......should make a post straightforward (with some flag like the Turret #) for someone skilled in post writing. Just to be clear, the Fusion 360 programming I setup so my CS is flipped in the X direction when I use the -X tools, meaning the paths and tools look like actual cuts on my machine, I just need to remember to put the G11 in for the appropriate tools because the post will yield +X values.
    Paul
    Quote Originally Posted by dammachines View Post
    Dave
  1. Toolpath Generation
    By Idiod in forum BobCad-Cam
    Last Post: 09-16-2015, 08:48 PM
  2. Toolpath generation problem
    By Poul M A in forum PhotoVCarve and VCarve Pro
    Last Post: 11-04-2014, 09:47 AM
  3. NX4 toolpath generation
    By thirumalkumarn in forum Uncategorised CAM Discussion
    Last Post: 05-27-2008, 01:47 PM
  4. How to generation toolpath ?
    By havythoai in forum Coding
    Last Post: 03-18-2008, 03:47 PM
  5. Full 4 axis toolpath generation?
    By Konstantin in forum Rhino 3D
    Last Post: 11-12-2006, 07:14 PM
