586,110 active members*
3,173 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF-5/50 alarm 235 - SPINDLE Z FAULT
Results 1 to 6 of 6
    Oct 2010
    30
    It is intermittent alarm 235 SPINDLE Z FAULT on VF-5/50. Usually during program run no problem, but when run spindle in MDI or MAnual mode CW, and then another direction, even by hand, appears Alarm 235. I have check encoder for grounding, mounting on the shuft, connectors on both sides, all is OK. But inside encoder was oil from transmission(( Some time appears Alarms116 (SPINDLE ORIENTATION FAULT), 237 (SPINDLE FOLLOWING ERROR). It seems encoder has to be change? With cable?
    Oct 2010
    30
    Re: VF-5/50 alarm 235 - SPINDLE Z FAULT
    I am not sure, because here http://www.cnczone.com/forums/showth...le%20Z%20Fault Alarm appears again, after new encoder was installed
    Feb 2016
    7
    We just had an alarm 830 Z Axis Serial Data Communication Fault alarm on our VF2ss. The fix after 2 weeks of the HFO service guy coming was a new data cable to he encoder/motor. I don't know how you can test the cable without a Hi-Pot test unit, but you could also try swapping out the cable from a different machine if available instead of wasting money.
    Oct 2010
    30
    Quote Originally Posted by 2015imsjfw View Post
    I just check connections and connectors itself.
    Feb 2010
    1184
    Quote Originally Posted by Andriy77 View Post
    If you found oil inside the encoder, then it is most likely bad.
    Oct 2010
    30
    I going to change encoder, but, interesting, generally it works OK, alarm appears when I turned spindle by hand in one direction, and then in opposite direction((
  1. Alarm # 123 Spindle Drive Fault
    By Web.eng in forum Haas Mills
    Last Post: 02-05-2020, 07:33 PM
  2. 1992 VF2 Alarm 123 spindle Spindle Drive Fault
    By dafowfidy in forum Haas Mills
    Last Post: 05-14-2012, 07:32 PM
  3. VF3 spindle high gear fault alarm #117 help!
    By JHR1 in forum Haas Mills
    Last Post: 01-01-2010, 05:39 PM
  4. Alarm 123 Spindle Drive Fault
    By Shotout in forum Haas Mills
    Last Post: 05-27-2007, 05:48 PM
  5. Alarm 235 Spindle Z Fault
    By Gomes in forum Haas Mills
    Last Post: 04-27-2007, 05:26 PM
