Dear Sirs / Dear Madams,
GREETINGS.
Thank you very much to all, for me to be a member of cnzone.com
I bought a Okuma Howa Millac 5VA Vertical Machining Center with Fanuc System 6M-Model: B and 4th axies Tsudakoma Model: RNCV-400 (L/R)
It was in working condition in USA and it is shifted to Thailand.
While unloading the machine, it slide down on ground from truck height and fall on ground such that the electrical panel resting on ground and damaged with the weight of machine.
The electrical panel is on the backside of the machine, looking from the front of machine. The hydraulic Power pack is also on backside.. but no damaged
The Z-axis motor back cover is broken.
Now I don't have Electrical Wiring Diagram for this. All other documents are available.
Right side Fanuc 6M Control panel is intact -- no damaged.
Left Side Tool Magazene, only plastic cover broken and this side having some electric indicator panel nbroken.
Now:: I want great help from all Sirs and madams:: as below::
1. I want Electrical Control Panel Wiring Diagram
2. If you anyone have a Refurbished Electrical Control Panel with facility of Input Power Supply as 400 Volt AC- 50Hz - 3-phase - 4 wire system
I want to buy.
In my Country Thailand, the power supply is 400Volt AC - 50Hz - 3-Phase 4-Wire
I request all to help me for this. and please advice the price for the same.
Waiting
Best regards
THAKOR
